changing plugs ???s
Old Mar 16, 2006 | 06:56 PM
mickeyiz28's Avatar
Angry changing plugs ???s
Well i attempted to change my plugs today, i got the #1,#3,#2, and #4 changed, i pulled plug 7 and now i cant get my new plug back in, also how in the world am i gonna get the #5 and #6 changed cuz i cant even hardly see them, anyone got any ideas on what i can do and how i can get the #7 back in
Old Mar 16, 2006 | 07:03 PM
FastZinTennessee's Avatar
Re: changing plugs ???s
Just take lots of breaks. The job is a major S.O.B. If you had headers it would be quite a bit easier.
Old Mar 16, 2006 | 07:11 PM
mickeyiz28's Avatar
its got slps on it
Old Mar 16, 2006 | 07:20 PM
chevy94c's Avatar
Do you have the shorter plug socket? Like SLP
Old Mar 16, 2006 | 09:37 PM
mickeyiz28's Avatar
nope, wished i did though
Old Mar 16, 2006 | 09:49 PM
TransAm-Z's Avatar
I have Pasesetter LT's on mine and have found the easiest way is to use the plug socket with a 3/4" wrench. Also some plugs are much easier to get from the bottom of the car. Seems like 1,3,5,& 7 are easiest from the bottom and 2,4,6,& 8 are best done from the top.
Old Mar 16, 2006 | 10:14 PM
Bow94z's Avatar
where do ya get the short plug socket from?
Old Mar 17, 2006 | 09:34 AM
chrisn's Avatar
slp has it or you could pick a regular socket up from sears or somewhere and grind it down.
Old Mar 17, 2006 | 09:41 AM
urbaNHunter44's Avatar
I found the best way to change plugs on the passengers side is to pull the Y-pipe. It will make things SOOOO much easier.
On the driver's side I was able to do them all without too much difficulty from under the car.
Old Mar 17, 2006 | 11:44 AM
xsk5's Avatar
be very careful when threading the plugs back in, don't force them in and don't overtighten. well..... unless you wanna pull the head off for a helicoil .
Old Mar 17, 2006 | 11:57 AM
kingman109's Avatar
slp shortys? if so i have them and hear your pain... the primaries run right over the f'ing plugs and at 1 3/4 makes it pia to change-
gotta do mine next weekend too...
Old Mar 17, 2006 | 06:54 PM
mickeyiz28's Avatar
i feel sorry for u already kingman, i tried it again today and managed to get the #8 off, but now i cant get the #7 or #8 back in, i dred getting the other 2 out, but it is definately pure hell trying to change plugs with slps
Old Mar 17, 2006 | 11:55 PM
Bow94z's Avatar
i dont see it anywhere on SLP's website....i remember they used to have it
Old Mar 18, 2006 | 12:03 AM
YZF/LS1 Freak's Avatar
I pulled my A/C and can get to all of them from the bottom, #8 is still a pain but it takes me about 15 minutes to do them all with stock manifolds from under the car.
I took a peice of vacuum hose on the end of the plug for the hard ones and started them with that. Just use the line to get the plug in the hole and turn it just enough that it starts and you can pull of the line.
Still have A/C and manfolds? good luck
Old Mar 18, 2006 | 08:03 AM
ABA383's Avatar
Check Ebay for that cut down socket...I remeber seeing them for like $12 on there...
--Alan
...or do it yourself....
