Autozone doesn't have IAC and dealer wants $120
Hard to believe. My car doesn't want to start unless I apply the pedal, and it has an erratic idle at times so I'd like to try the IAC. But not for $120. Can they be repaired or bought for a reasonable price?
Re: Autozone doesn't have IAC and dealer wants $120
Is this what you're looking for?
http://www.partsamerica.com/ProductD...pe=757&ptset=A
Not sure if they're the same for every year. Advance Auto probably has one for you, but you might have to order it online, some of the parts they have aren't available in the store.
What he said. I needed one a couple years ago and this is what I did. Not a common failure so nobody stocks them.
As stated above, you can clean it. Just be a little careful and don't push the pintle around. I did this to mine and have not had any problems since. Go this route before buying a new one.
http://shbox.com/1/4th_gen_tech2.html#iac_reset
Nellsw88
May 27, 2015 10:27 PM
eanhl2004
Apr 4, 2015 12:01 PM
