AS&M 58MM on a 93Z??
Old Mar 14, 2006 | 06:01 PM
BadAssed93Z's Avatar
there is only one listing for an LT1 TB on AS&M's website and it looks just like the one i have, it also says no wire modification is required and uses stock TPS and IAC. the TPS looks fine but it uses a bolt in style IAC that is different from my 93. has any one had this happen before? anyone have any suggestions?
thanks alot guys.
Old Mar 15, 2006 | 08:09 AM
Re: AS&M 58MM on a 93Z??
anyone? I tried calling AS&M but i got no answer.
thanks
Old Mar 15, 2006 | 11:08 AM
Bersaglieri's Avatar
thanks
Same here, called yesterday too. Although today it said that the line was busy and I left a voicemail. I had some questions about my AS&M 58mm TB.
I'm trying to figure out if it will work with a 700R4 TV cable, you probably should too.
I'll go look at mine.
-Dustin-
Old Mar 15, 2006 | 11:19 AM
WS Sick's Avatar
You can use the stock IAC housing from your 93s T/B. The real issue would be the TV cable stud on the linkage. I have one on my 97 and the IAC housing was used from my stock T/B. But of course the 97 has no 700 lug on it.
Old Mar 15, 2006 | 02:12 PM
I spoke with and emailed a picture to AS&M of my 58mm TB. The representative I got ahold of through AIM user name "AZSpeedandMarine". Who thought that would work better than a phone call? Anyways he said that near the top of the plastic plate there is a 1/4 drilled spot that doesnt go all the way thru. He said all I would need to do is drill that thru to fit the TV cable and it should work fine. Hopefully that clears things up with you guys. Good luck.
-Dustin-
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
bunker
Aug 1, 2015 09:47 PM
