cloyes double roller on 94
Old Mar 13, 2006 | 01:43 AM
Daniel6718's Avatar
is this possible? with some grinding? or i see some people sayin i have to get a 95 up cover and opti?
im scared of my lt1 timing set and 6500+ rpm
Old Mar 13, 2006 | 02:59 AM
1racerdude's Avatar
Re: cloyes double roller on 94
Got to convert to '95.Cam too.
Old Mar 14, 2006 | 12:48 AM
Daniel6718's Avatar
so i have to have a 95 timing cover? whats the differance? does my opti have to be changed? the cam i thought was the same?
anybody have more detail or a writeup?
Old Mar 14, 2006 | 01:06 AM
Z95m6's Avatar
you need the cam, the opti, the timing cover, chain and the opti harness
Old Mar 14, 2006 | 01:53 AM
Daniel6718's Avatar
ok so whats the best chain for my car then? without chaginc my cam and opti
i already have a cc306 and a electric waterpump and new 94 opti with dowel pin
Old Mar 14, 2006 | 04:16 AM
93camaroLT1's Avatar
I kinda ran into this problem with my car also... Anyway you put it you got to run the stock timing set or another LT1 timing set (lunati, etc.), which all are pretty much stock LT1 quality timing sets and also all non-roller sets.
OR
Replace the opti for a vented opti, get a 95+ cover, cam, and the opti harness, couple hoses, etc. (which adds up too well over $500 just for the opti swap alone from gmpartsdirect.com not including the cam.)
And then you can finally get either the cloyes double roller or a LT4 timing set.
OR
Comp Cams makes a double roller timing set for the 1st generation LT1 timing set which will work with your stock opti.. I believe this will also work with the stock H20 pump. Only catch is that this timing set is over $500
So, pretty much anyway you put it if you want anything better than the stock timing set your gonna have to expect to spend over $500 on it is what it comes down to.
Old Mar 14, 2006 | 05:25 AM
sssalah's Avatar
You don't need to change the cam, just replace the dowel pin on the with a longer one.
Old Mar 14, 2006 | 06:25 AM
BlackDog's Avatar
These are your only choices for a 94 motor.
The Cloyes - CLO-9-9100
Lunati - LUN-93094
or the factory replacement.
The Cloyes and Lunati will state that the parts are for 92-93 only. I called them directly and they both said that they are a direct fit for the 94 motor. The reason that they do not include the 94 year is that some late model 94's came with the 95 setup.
You would think that they would say that it would fit some early 94's. But they don't.
Old Mar 14, 2006 | 01:28 PM
Daniel6718's Avatar
so if i get a 95 timing cover that is all i need it is a direct replacement?
and then i have to get a 95 opti that doesnt have a keyed pin out of the center of the cam it runs off the dowel in the cam that is off to the side?
is there any way to make that longer or replace it if i already cut it for my 94 opti?
Old Mar 14, 2006 | 08:37 PM
You can't use a 1994 and earlier cam with a vented opti, even if you use a longer dowel pin. The hole that is drilled in the front of the stock 1994 and earlier cam is too small. You must change the cam or have the nose of it drilled out.
Old Mar 15, 2006 | 01:08 AM
Daniel6718's Avatar
so what is my best option for my car?
is there any other double roller i can used on my car?
i have a cc306 cam with the keyed dowel pin, any way to make it work?
Old Mar 15, 2006 | 03:33 AM
Only real things you can do to get a better timing set is either do the opti swap, which will give you a lot more options towards a better timing set or go with the comp cams double roller timing set (CCA-3206) which goes for a bit over $500... which, depending on how you go about things may be still decently cheaper than the opti swap. The one kindof big thing that most people leave out when they talk about doing the opti swap is the harness which just happens to cost $75 at gmpartsdirect.com price.
Old Mar 15, 2006 | 11:09 AM
sssalah's Avatar
That applies to stock cams, he already has a cc306. All aftermarket cams I've seen have a large hole drilled and some come with 2 pins short and long to work on both applications.
Old Mar 15, 2006 | 11:13 AM
WS Sick's Avatar
That's really pot luck as well.
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Bxlt1
Sep 10, 2015 08:16 AM
