383ci= running like crap and backfireing...
Old Mar 15, 2006 | 12:14 PM
speedracer69's Avatar
383ci + other bolt-ons.
problem.. After start up for like the first min and 1/2 the car runs perfect. nothing wrong.
After that.. my car starts missing from 800rpms to about 3,000rpms. during this time it will slip flames and pop very loud. its not from the same cly each time because i have duals and it seems to be from different sides at differenet times.
On the highway i can't use 6th because it lugs the motor tomuch and makes it miss and backfire.
The car is not running any codes. 40psi on the fuel.
I have check for lose wires and so on but nothing..
HELP!!!
Old Mar 15, 2006 | 12:25 PM
KillWhitey's Avatar
Re: 383ci= running like crap and backfireing...
Check to make sure the wires go to the right plugs. I crossed two when I did my lt install and it ran like you described.
Old Mar 15, 2006 | 12:41 PM
That is fine. The car has been running good untill last week when this stuff started
Old Mar 15, 2006 | 01:14 PM
turbo_Z's Avatar
Get a datalog! Sometimes people have problems with the ICM located beside the coil. Supposidly the searing heat generated by the heads will start to affect the sensor. Moving the coil off the head or spacing it off the head will help but Id start my replacing the ICM and/or the coil. Or swap with a friend if you can.
Old Mar 15, 2006 | 01:39 PM
Ok turbo Z i just did what you said... i moved it off the head. I will take it on a test drive and let you know what happends
Old Mar 15, 2006 | 02:07 PM
OK just did that and no change. I even had another coil and ICM and changed it.
Still does the same thing
Old Mar 15, 2006 | 02:18 PM
KillWhitey's Avatar
The wires might be arcing. Run it at night and you might be able to see where your problem is.
Old Mar 27, 2006 | 10:17 AM
The wires fixed it!
Old Mar 27, 2006 | 11:01 AM
firebirdStud's Avatar
what wires were you running that arced? What did you switch too? I am trying to find some decent wires for my car!
Old Mar 27, 2006 | 11:18 AM
I had MSD wires. they are good but very easy to mess up.
I got the ellite 9mm OVC wires. They look better and stay away from the headers!!
Old Mar 27, 2006 | 11:37 AM
wow, you got some ellite's recently? I have read a couple posts that they were not doin so good. Well, Thanks for the help!
Old Mar 27, 2006 | 12:49 PM
Not too recently.. about 3 months ago. Just got around to installing them
dirtybird81
10
Jan 6, 2015 09:31 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
