question about air pump wires.. whos hot?
Old Mar 12, 2006 | 03:28 PM
96trans am's Avatar
I am going to use the air pump wiring to power my electic waterpump since I deleted the air pump. I was wondering what wire is hot. Does anyone know? Thanks in advance. -Matt
Old Mar 12, 2006 | 03:41 PM
snorkelface's Avatar
Re: question about air pump wires.. whos hot?
Since the air pump is only working the first couple of minutes after start up, how will you keep the power going to the pump?
Old Mar 12, 2006 | 04:55 PM
96trans am's Avatar
Hmm.. I guess you'r right. I need to only use the fuse from the airpump. Wish there was an easy right up on this for an OBDII LT1 car.
Old Mar 12, 2006 | 06:59 PM
Dave89IROC's Avatar
i just saw one a few days ago, i'll look
Old Mar 12, 2006 | 07:00 PM
Why not wire it with the fuel pump? If the fuel pump isn't on, the car ain't runnin'!
Old Mar 12, 2006 | 07:02 PM
96trans am's Avatar
Hey whatever works man I am down for. I just seen someone suggest running it to the air pump fuse. And considering I just took mine out I figured why not run it that way. Im open to all suggestions and any good write ups regarding how to run an electric waterpump. -Matt
Old Mar 12, 2006 | 07:17 PM
stroked383z28's Avatar
Just get a relay and wire it up like this:
85 -- ground
86 -- any switched +12V wire (This will wire will activate the relay. It doesn't really matter where you grab this wire at since it takes very little current to activate a relay. Any wire that is hot when the car is on and not when the car is off will do.)
87a -- N/A
87 -- Positive wire from the water pump
30 -- Battery (You can go right to the distribution block on the passenger fender)
Then just ground the negative wire from the water pump and you're done. This way you will be pulling current straight from the battery and not another circuit in the car.
HectorM52
Jul 30, 2017 11:46 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
CamaroZBoy
Aug 19, 2002 12:41 PM
