I need help with a miss, I've basically tried everything
Old Mar 15, 2006 | 07:41 PM
speed_demon24's Avatar
I cant fix the miss, its been there for about a month, it started out as barley noticeable, and now it sputters and backfires out the intake/exhast. So far I've put in a new opti, tried a new coil, tried the ICM, changed the plugs, and a new coil wire. The fuel pressure is 50psi with the vacume line disconnected, 44 with it connected, with a stock fuel pressure regulator. When I rev it in neutral, it jumps to 50psi with the line connected. The only thing I can think of is its the wires, but I started it up in my garage in the pitch black and didn't see any arcing at all. I'm ****ing fed up with this ****
Edit, It does it cold or hot, doesn't make a difference, it does it as soon as i pull out of my driveway. And I changed the 02's that didn't help, and it does it before it starts reading the 02's. The passenger bank header tubes read about ~100 degrees hotter after a 2 minute drive than the driver side if that makes a difference. And its more than 1 cylinder missing, its all of them.
Old Mar 15, 2006 | 07:49 PM
speedbikelvr's Avatar
Re: I need help with a miss, I've basically tried everything
I had the same problem and changed about the same as you (opti, coil,coil wire cap and rotor re-set the valves, new plugs) and still had the same problem. It turned out to be a bad plug wire set, I changed my wires and it runs great with no miss. Man I was so pissed!! Hope this helps with your problem.
Old Mar 15, 2006 | 07:54 PM
Is there anyplace that sells the accel wires that you can cut for the OVC locally?
Old Mar 15, 2006 | 07:57 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Just narrowed down my miss to bad wires as well...
Old Mar 16, 2006 | 09:27 AM
Digital Designs's Avatar
ive never had a problem with oem wires....
Old Mar 16, 2006 | 09:43 AM
missetti's Avatar
Ususally start with the simple things first, like the spark plugs, and the wires, then move on to the more difficult. When I change my plugs, I always spray an electrical cleaner on them and wipe each plug off to make sure that they are clean. Just having the oil or dirt on your hands can cause an arcing and miss. I learned the hard way that with the high voltage that these cars have, that its the little things that will drive you crazy. I run MSD wires and have never had a problem with them.
Old Mar 16, 2006 | 09:48 AM
Have you ever had it scanned to look at the misfire counts for each individual cylinder? That might help you pin down the problem.
Old Mar 16, 2006 | 05:26 PM
Lazlo's Avatar
Maybe a clogged or leaky injector?? That's only thing I can think of that would be diff from one side to the other. How's the coolant temp? Check each plug wire for resistance with a DVOM, they can fail without arcing anywhere.
Old Mar 17, 2006 | 11:51 PM
Well I took it to a mechanic. The compression is good, fp is good, fuel injectors are good, valve lash is good. He said only 3 cylinders were firing correctly. I'm having MSD wires overnighted from summit, so I'm gonna give those a try tomarrow.
Old Mar 18, 2006 | 02:51 AM
smoknta's Avatar
Also, check your opti connector and harness for corrosion or a nicked wire. You may have a good opti, but it might not be getting a good signal to the PCM.
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
BMX Dad
Jul 27, 2015 02:39 PM
94Form
Jul 17, 2015 10:56 PM
ducttape1975
Jul 10, 2015 06:29 PM
