Am i over-analyzing this.. Timing chain installed wrong??
Old Mar 15, 2006 | 09:32 AM
sabre81's Avatar
Question Am i over-analyzing this... Timing chain installed wrong?? confused..
I'm at work and i'm wondering if it's possible that i installed the timing chain wrong? What i did was was, with the #6 cylinder @ TDC(or what i thought was TDC), i installed the chain with the cam gear dot at 6* and the crank gear dot at 12. (cam dowel at 3)
The way i found TDC was using a screw driver in the spark plug hole.... Now i find that both the #1 & #6 piston is at the top at the same time(not sure why that didn't hit me before..) Could i have installed the chain backwards? Maybe with the #6 piston on the exhaust stroke instead of the compression stroke? OR does it not matter? I'm confused.... HELP!
Old Mar 15, 2006 | 11:13 AM
sabre81's Avatar
Re: Am i over-analyzing this.. Timing chain installed wrong??
bump.. anyone?
sorry for the quick bump.. i need to figure this out before i go crazy
Old Mar 15, 2006 | 11:29 AM
atljar's Avatar
The crank itself doesnt care if its at #6 or #1 TDC. The cam's position decides what piston is on which stroke. If the crank gear was keyed on correctly, its dot will be at 12 oclock at TDC. The Cam gear can either go at 6 (for #6 TDC compression), or at 12 (for #1 TDC compression)
Old Mar 15, 2006 | 11:36 AM
1quickTA's Avatar
Don't your gears each have a dot on one of the teeth? Just line up the dots on the teeth. It is pretty fool proof that way. When installed correctly, the dotted crank tooth will point straight up and the dotted cam tooth will point straight down (towards each other) at some point during their rotation.
Old Mar 15, 2006 | 11:43 AM
Javier97Z28's Avatar
Moderator
If your gears were dot to dot you have nothing to worry about in regards to being a tooth off. There's no front or back to the chain.
Old Mar 15, 2006 | 11:50 AM
sabre81's Avatar
Yeah the gears were dot to dot, with piston #6 at the top of its travel. I then rotated the crank so that the cam gear's dot was at 12 & the crank gear's dot was also at 12. Then put on the timing cover and balancer hub with the arrow facing up. all good?
Old Mar 15, 2006 | 12:05 PM
1quickTA's Avatar
All good. If you were dot-to-dot then you can sleep tight. Good luck with the rest of the install.
Old Mar 15, 2006 | 12:06 PM
Moderator
Old Mar 15, 2006 | 12:17 PM
sabre81's Avatar
Thansk guys. Can't wait to fire this bad boy up on saturday.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
