How do I know if my Opti-spark is vented?
Old Mar 14, 2006 | 07:30 AM
Rage's Avatar
This may sound like a dumb question, but I really need to know. See, when I bought the LT1 from the guy, he told me it was out of a 94 Z28. But, I was going to buy an Oil Pressure switch which I believe on a 93 and 94 was located on the side of the block by the oil filter if Im not mistaken, but mine is on the back of the intake, under the EGR unit. So, Im just looking for ways to check for sure what year my engine is. Thank you.
Old Mar 14, 2006 | 07:44 AM
Javier97Z28's Avatar
Moderator
Re: How do I know if my Opti-spark is vented?
You'll see two vacuum lines going to it. One from a little hole in the elbow, and the other goes to a port on the intake manifold.
Old Mar 14, 2006 | 07:47 AM
Rage's Avatar
The only thing I see is the spark plug wires, and the plug in port for the opti, so I guess it is a 94, but why is my oil pressure switch on the back of the intake?
Old Mar 14, 2006 | 07:50 AM
Moderator
Nah, it's on the back of the block on all of 'em as far as I know, right behind the intake manifold like you said.
Old Mar 14, 2006 | 09:54 AM
OBE1 95Z28's Avatar
Here's a photo of a vented opti from Shoebox's site:
http://shbox.com/1/opti_vacuum_harness.jpg
Old Mar 14, 2006 | 10:06 AM
Harvey's Avatar
Thumbs up Re: How do I know if my Opti-spark is vented?
1993's and early 1994's were located on the left hand side of the block above the oil filter. So yours is just a late 1994. Also, I'm not 100% sure, but I think all the LT1's have a spot above the oil filter where you can put the sensor. I know mine does.
Old Mar 14, 2006 | 10:40 AM
atljar's Avatar
Ya mine is a 94 and has the oil pressure sensor behind the intake. I too believe they all had a port there and above the filter on the block
Old Mar 14, 2006 | 10:50 AM
Shoebox has a photo of the oil pressure connection above the filter as well.....
Old Mar 14, 2006 | 10:59 AM
Moderator
hah! I stand corrected.
Old Mar 15, 2006 | 12:56 AM
Rage's Avatar
I found out mine is just a late 94. But, now I have an all new question for you. I just got my MSD cap and Rotor from O'rielly's, and by the way, they had the Borg Warner cap and rotor at $224 and the MSD at $165, but none the less, I got it today, MSD PN# 8481 and it has what apears to be vents. Now, on the bottom there is a large vent and on the top by the connector there is another. The instructions say this is to be hooked up to a vaccum and will ventilate the opti. Does the work? Can someone shed some light on this for me?
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
tdigger9899
Sep 7, 2015 10:56 AM
whitehooptie
Jul 12, 2015 06:10 PM
Jul 10, 2015 02:23 PM
