Gas still in oil?
Old Mar 14, 2006 | 07:08 PM
ChrisUlrich's Avatar
Gas still in oil?
Had injectors tested... no leaking.
So I put them back in, lowered the fuel pressure A LOT, but still have fuel in the oil? HOW?!!?!?!!
Old Mar 14, 2006 | 07:13 PM
RE AND CHERYL's Avatar
Re: Gas still in oil?
Bad fuel pressure regulator. The diaphram is ruptured allowing fuel to pass into the intake through the vacum line. WHen you shut off the engine the excess fuel pressure runs into whatever valve is open and drains past the rings into the crank case.
Re'
Old Mar 14, 2006 | 07:43 PM
Evil Eric's Avatar
Pull the vaccum line from the regulator that goes to the manifold, if theres gas in there youve found your culprit.
Old Mar 15, 2006 | 06:23 AM
it's clean... nothing
Old Mar 15, 2006 | 07:25 PM
Guest47904's Avatar
Guest
Put a manual vacuum to the FPR. See if you get fuel. If not the only other cause for crankcase dilution is dead cylinder(s).
Old Mar 15, 2006 | 09:47 PM
What does a Dead Cylinder mean?
I have a dyno chart and the car put down 430rwhp 415rwtq on a pretty solid graph...
Could a Dead Cylinder still occur?
Old Mar 17, 2006 | 03:18 PM
No one?
Old Mar 18, 2006 | 09:57 AM
No one at all?
Old Mar 18, 2006 | 12:17 PM
Honda Hunter's Avatar
What's the a/f ratio? Just curious.
Old Mar 18, 2006 | 12:35 PM
turbo_Z's Avatar
Its probably running rich.
Old Mar 19, 2006 | 01:15 PM
I don't have the exact specs... I am so stupid though. I can't believe I didn't get the chart from them when it was Dyno Tuned. Ugh...
Old Mar 19, 2006 | 01:35 PM
turbo_Z's Avatar
There is more to the air/fuel ratio than a WOT dynotune. The gas is getting in the oil during idle and part throttle driving.
rideordie
Nov 5, 2019 04:52 PM
AtlasXVIII
Aug 2, 2015 10:29 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
simple
Aug 11, 2002 11:56 AM
