cam button
Old Mar 15, 2006 | 01:50 PM
383ysi's Avatar
cam button
Need to know of you use a double roller, and lose the opti/go with distributor. If the timing plug part# 12367600 from gm, you can use a cam button or how do people keep the cam from walking.
Old Mar 15, 2006 | 02:01 PM
Javier97Z28's Avatar
Moderator
Re: cam button
The cam retainer plate will keep it from walkin'.
Old Mar 15, 2006 | 02:07 PM
383ysi's Avatar
Re: cam button
with the double roller we couldn't use the retainer plate
Old Mar 15, 2006 | 02:10 PM
Moderator
Re: cam button
What double roller set are you using?
I'm running the Cloyes 3145 double roller and the cam retainer plate fits just fine.
My friend is running the Comp double roller and runs his retainer plate just fine as well.
Try one of those sets instead.
Old Mar 15, 2006 | 02:25 PM
383ysi's Avatar
Re: cam button
i believe it is a pmm or prm
Old Mar 15, 2006 | 02:26 PM
383ysi's Avatar
Re: cam button
What kind of modifing did you have to do to the cover. thanks
Moderator
Re: cam button
Hrm, not familiar with that, all I know is those two I mentioned above work fine with the cam retainer plate. Never heard of anyone using a cam button with our cars.. doesn't mean it's never happened, just never seen it.
Go with what works IMO
To the cover I took a die grinder around the thick part of the inside around the opti spark hole. Install the chain setup, rub some grease on it, put the cover on, turn the engine over by hand and see where the grease rubbed off. Shave some off, test fit again until you have no grease left.
Old Mar 15, 2006 | 02:39 PM
383ysi's Avatar
Re: cam button
Sorry also forgot to mention we had the cam cut the old style.
Old Mar 15, 2006 | 02:43 PM
Moderator
Re: cam button
I'm not familiar with what ya mean on that, sorry
Old Mar 15, 2006 | 02:51 PM
383ysi's Avatar
Re: cam button
The cam isn't cut for the lt1, its cut for a older style 350. The only difference is for the retainer plate.
Old Mar 15, 2006 | 03:53 PM
1racerdude's Avatar
Re: cam button
WHY?????
Ya opened up a whole new can of worms.
If ya MAKE a button make sure it fits as to not let the cam walk more than .010.
rideordie
Nov 5, 2019 04:52 PM
tds1213
Nov 27, 2014 12:55 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
Black Sunshine/ 00SS
Jul 22, 2002 09:58 AM
