30ibs svo injectors
Old Mar 10, 2006 | 10:28 PM
lr383's Avatar
30ibs svo injectors
A question for you guys! can you run 30lbs ford 30 lbs injectors with a stock 24 lbs injector program tune? Having trouble loading up grade program with new cables. It just a injector change.
Old Mar 10, 2006 | 10:35 PM
96camaroSS's Avatar
Re: 30ibs svo injectors
If you don't change the injector constant you will not see the results you are looking for. But I see you have a 383 so you'll probably be fine since it needs more fuel to feed the cubes and the cam you're running.
Old Mar 10, 2006 | 10:40 PM
A 30# SVO will flow about 31.6 #/HR at your stock fuel pressure. If the PCM is tuned for stock injectors, it should be set at 24.9 #/HR. That means the SVO's will flow 27.0 % more than the stock injectors. The long term fuel corrections can only pull 15.6% excess fuel out. In closed loop, you will be relying on the short terms for pull the rest out. At WOT/PE mode, you will be running 27% rich. That means a well-tuned 13.0:1 will run at 10.2:1. That's probably rich enough to foul plugs and start to wash the lubrication off the cylinder walls, put fuel in the oil and generally mess things up.
"It just an injector change".
Old Mar 10, 2006 | 10:41 PM
lr383's Avatar
Iam sorry guy I should stated this for my sons ta, It as a 355 in it with le2 heads we our changing the injectors.
Old Mar 10, 2006 | 10:48 PM
It doesn't matter what the displacement is. The MAF (assuming your son's car is not a 93) will see the actual air flow, whether its a 383 or a 355. The MAF gets the air flow right, the PCM multiplies the MAF reading by the target A/F ratio to get the mass flow rate for fuel. If the engine consumes more air because of the displacement, the PCM will be able to compensate. But when you put in an injector that flows 27% more than the PCM thinks it will, it provides 27% excess fuel above the amount calcualted from the mass air flow.
Old Mar 10, 2006 | 10:52 PM
lr383's Avatar
Thanks for the repy, that answer my question .
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
