Change Cam bearings??
Old Mar 12, 2006 | 09:59 AM
fastformula309's Avatar
Question Change Cam bearings??
when i do my cam swap do i need to install new cam bearings or is it just recommended? What will happen if i don t change them, anything bad??
Old Mar 12, 2006 | 11:40 AM
93redlt1's Avatar
Re: Change Cam bearings??
depends on miles on how the oil press is. if its like 20 warm and 50 -60 normal driving you should be fine. i had only 65k miles on mine and wanted to change the cam and the bearings were shot so i just pulled it and rebuilt.
Old Mar 12, 2006 | 11:51 AM
1racerdude's Avatar
Ya can't change them unless ya bring the engine out of the car.
Old Mar 12, 2006 | 03:48 PM
Tricked-Out-Toy's Avatar
You know I thought the same thing, so I wasnt planning on taking my 67K engine out to do my head and cam swap, but when i pulled the cam it was ridged and the bearings were pure copper with scratches I could catch my finger nail on. my oil pressure was great when warm it would never drop below 25 and during driving it would run all the way up to 55-60. I looked at the cam and cam bearings and was in pure shock. so friday I pulled it and looked at the crank bearings and they were perfect along with the cylinder bores(no lip, plenty of cross hatch). so I dontk now what the hell happened but dont just assume you can do the swap without looking at the bearings. I made that mistake and now my project deadline is getting pushed back
Old Mar 12, 2006 | 05:02 PM
so basically i wont be able to tell if i need to do them untill i have the engine ripped appart?
Old Mar 12, 2006 | 10:01 PM
I can only give you my experience, BUT I would make sure you have some time and money just in case.
StansZ28
Feb 19, 2015 07:39 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
