AF what should it be???
Old Mar 16, 2006 | 09:10 PM
scottslt1z28's Avatar
i am running way to lean at WOT...............what should i be running? i will be calling Bryan at PCM4less tomorrow because im running 14.2 at WOT and that really scares me
what are some of you guys at?
--Scott
Old Mar 16, 2006 | 09:21 PM
96camaroSS's Avatar
Re: AF what should it be???
I believe 12.5 is closer to where you want to be with a N/A motor at WOT.
Old Mar 16, 2006 | 10:59 PM
Originally Posted by Chopstix
deleted
you're funny
Old Mar 17, 2006 | 12:18 AM
LT1 POWR's Avatar
I made the most power/torque at about 12.8, this is with alot of tuneing to find the right ratio.
Old Mar 17, 2006 | 07:59 AM
1quickTA's Avatar
^^^ thats right about where you want to be.
Old Mar 18, 2006 | 01:15 PM
BIG SHAFE's Avatar
12.7 is about where you want to be, and 12.2 is optimal (so I've read and seen results in engine dyno tuning) at max VE.
Old Mar 18, 2006 | 02:52 PM
HardcoreRM125's Avatar
14 to 1 is lean. But its not so lean that its going to hurt anything. Dont be afraid to drive the car. Just get it tuned.
As everyone else has said, peak power seems to vary from car to car, but generally its between 12.5 and 13:1 on a NA motor. I think the variations between everyone on here who is NA that is making peak power at different AF ratios is because of the condition of the car. Engine condition and spark system condition probably play a big role in it.
Peak power should be closer to 13:1.
And I would bet that most of the people at 12:1 making peak power likely would show a weaker spark, on average, compared to the guys who are doing it at 13:1 Cause if you dont have as strong of a spark, a little more fuel is easier to ignite.
I'm just reaching out on a limb with that one though. But at anyrate, it should be around 13 to 1. High 12's maybe.
Old Mar 18, 2006 | 03:11 PM
ABA383's Avatar
13:1 here...Tuned by Bryan at PCMforless on the dyno...came to him at 12.2:1 and picked up 20rwhp with the A/F and timing...N/A
--Alan
Old Mar 18, 2006 | 03:14 PM
CompreSSor's Avatar
i'm 13.5 but i'm supercharged.....
Old Mar 18, 2006 | 03:49 PM
BIG SHAFE's Avatar
There isn't one peak power AF, there are 2; lean best torque and rich best torque. Each produce max power but have different dis/advantages.
Old Mar 18, 2006 | 03:53 PM
rskrause's Avatar
Moderator
WAAAY to lean for a blower car! Ouch.
NA LT1's typically make best power in the high end of the 12:1 range. You ARE way to lean at 14.2:1. Are you sure that's your real AF ratio? Is this measured with a wideband sensor that is correctly calibrated? If so, the tune is really fecked up and should avoid running at WOT or you may break or melt stuff big time.
Rich
Old Mar 18, 2006 | 07:43 PM
Rich
my conclusions after speaking with bryan and a few other people are that the dyno guys are retarded (and my readings were inaccurate)
They hooked up my stuff really strange (i even pointed it out when i was at the dyno, but they said i was wrong...........turns out i was right) so i wont be going there anymore.
Im going to head to Thunder this summer and have them dyno it and tune it because i will have a few more things come summer.
But at least i know what to look for now.
Old Mar 18, 2006 | 09:01 PM
Firehawk_Dude's Avatar
Is that static or dynamic CR?
Old Mar 18, 2006 | 09:22 PM
ABA383's Avatar
He's talking about his A/F ratio...
--Alan
Old Mar 18, 2006 | 09:28 PM
turbo_Z's Avatar
To be so lean with your mods Id suspect a fuel pump problem.
