correct Spark plug gap?
Old Mar 15, 2006 | 06:07 PM
automike25's Avatar
Does anybody know what the correct spark plug gap for the LT1 is? and would any of you suggest using dielectric grease on plug- boot and opti-boot connections.
Old Mar 15, 2006 | 06:18 PM
automike25's Avatar
Re: correct Spark plug gap?
NGK TR55IX's is what ill be putting in
Old Mar 15, 2006 | 06:23 PM
disco192's Avatar
Dont gap iridium! (I assume IX means Iridium)... Otherwise .045-.05
Old Mar 15, 2006 | 06:32 PM
automike25's Avatar
yeah they are iridium. why dont you gap iridium?
Old Mar 15, 2006 | 06:56 PM
KillWhitey's Avatar
most plugs come pre gapped
at least the ones I have used do
Old Mar 15, 2006 | 07:26 PM
1racerdude's Avatar
Take a "Q" tip and put die electric in the boot.
IMO the exotic metal plugs have a problem with the caps of exotic metal poping off,that's why I don't use them.
I gap my plugs at .035,that's with regular plugs,'cause it takes a big load off of the opti.
Old Mar 15, 2006 | 11:02 PM
Stock gap is .050" and printed on the label on the radiator cover. You should always check the gap even on pre-gapped plugs.
Old Mar 15, 2006 | 11:37 PM
scottslt1z28's Avatar
what he said
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
