Engine stumble
Old Mar 14, 2006 | 06:08 PM
Gvnitup's Avatar
Engine stumble
I have a kind of newby question, I cannot remember what stock fuel pressure should be with a stock regulator. Shouldn't stock fuel pressure be 40-45 psi with the vacume line hooked up. I have a stumble upon a load. I think it is the filter, My pressure is 30 psi until you load the engine then it jumps to 40, but it quickly drops back down to 30. Again i think it is the filter, please help me.. Humor me.. thanks Guys..
Oh and anyone intrested in a 95 firebird a-4? 3800 ?
Thanks again
Old Mar 14, 2006 | 08:58 PM
Sweetred95ta's Avatar
Re: Engine stumble
The pressure should be around 41 psi with the key on and idleing. 30 psi just isn't going to cut it. Check the filter, then the pump. Good luck.
Brake_L8
Jan 20, 2015 09:44 AM
AlaskaZ28
Dec 10, 2014 02:37 PM
Lions3
Apr 11, 2003 10:55 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
Dave19yz28
Jan 26, 2003 01:45 PM
