Throttle got stuck open
Old Mar 13, 2006 | 10:02 PM
Honda Hunter's Avatar
I have a BBK throttle body. Last night while driving in part throttle it got stuck so I had to turn the car off. What can I do to prevent this from happening again?
Old Mar 13, 2006 | 10:16 PM
turbo_Z's Avatar
Re: Throttle got stuck open
Do you know why the throttle blades stuck open? There are several ways this could happen.
Old Mar 13, 2006 | 10:52 PM
Evil Eric's Avatar
sometimes carbon/gunk buildup from inside the manifold will cause the throttle blades to stick. take some choke cleaner to it.
Old Mar 13, 2006 | 11:26 PM
Josh'95Z28conv's Avatar
When I first bought my car, it did that a couple times. I took off the intake elbow, and found duct tape holding the throttle open The elbow was cracked, and the previous owner tried to fix it with duct tape, on the bottom. I retaped it I later did a compression and leakdown test. All was good.
I dont know whats wrong with yours, you just reminded me of this and made me laugh
Old Mar 13, 2006 | 11:47 PM
TheNuge876's Avatar
I had something that came loose and was actually hooking up on it and holding it down, make sure everything is properly attached too.
oldschool
Feb 9, 2016 09:21 PM
95z_28_camaro_4_Ivan
May 10, 2015 09:28 AM
edman
Jan 22, 2015 02:45 PM
