My 94 Z28 wont fire up.
Here my problem... 1994 Camaro Z28
Opti is good whe I have taken it off, MSD coil is good along with other parts to make a car run.
I took every off and out to fix an oil leak coming from the water pump drive gear seal. I took my time with doing making sure the opti didnt get wet in which it didnt.
Now, I put everything back together today and went to start it up and it wont fire... It has fuel pressure cause I can smell it and I check the sharder valve, its just not getting any spark, not even from the coil pack.
I checked all fuses in which are good, swapped the old coil pack in and tried again and still no fire.
Any Ideas?
Any Ideas?
Re: My 94 Z28 wont fire up.
Any Ideas?
Any Ideas?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
