High rpm clatter
Old Mar 12, 2006 | 03:25 PM
TripKidd's Avatar
High rpm clatter
Well, I've been chasing a pretty strange problem for a while.. when accelerating as my engine gets up near 5600 rpm I start to hear a clattering sound, that progresses to an almost grinding sound towards 6000 rpm. I cant seem to figure it out.
I have ruled out valvetrain problems I believe as I have replaced the stock springs and rockers with pro magnum SA 1.6 roller rockers and CM EX-614 springs. (iron head LT1 btw).
I have ruled out transmission as that took a dump and was rebuilt a year ago (oh, and 3 times since then under warantee, which is now out, yay.)
so... I dont believe it to be detonation as I dont see anything wierd on my datamaster scans.
in neutral with no load I was able to rev it to 6300RPM for a second with no clatter...
power is good. no drop off associated with the sound.
any ideas? just to be safe I have my car completing my shifts by 5500rpm..
on impalasforums.com I found a guy who had the same problem with a completely different engine setup, never figured out the problem. never had a problem with many runs on the car. sold it a year later to by a z28... so no help there.
Thanks for any ideas!
Old Mar 13, 2006 | 11:05 AM
TripKidd's Avatar
Re: High rpm clatter
ahh, I know I didnt stump you guys with this one
any input? should I post this in advanced tech?
Thanks again -Ryan
Old Mar 13, 2006 | 11:18 AM
Stoopalini's Avatar
What car do you have, how many miles are on it, and which mods do you have?
A sig would really help people answer your question
Thomas.
Old Mar 13, 2006 | 11:20 AM
Cmr0z28's Avatar
Remove the serpentine belt and see if it still does it. Mine did something similar when my crank pulley was splitting in half.
Old Mar 13, 2006 | 11:27 AM
Honda Hunter's Avatar
Do you have poly replacement mounts on the tranny and motor? Mine does it like crazy from the tranny.
Old Mar 13, 2006 | 11:45 AM
TripKidd's Avatar
Alright, I got a sig up.
Thanks for the suggestions.
I'll try removing the belt & see what happens.
& no, I have not replaced the factory mounts with poly mounts.
blac94Z
19
May 13, 2015 04:50 PM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
jayblev95
Dec 1, 2014 06:55 AM
PhantomTA
Aug 17, 2002 12:19 AM
