Electric cutout problem
Old Mar 12, 2006 | 02:15 AM
ddj19852003's Avatar
Does any one know why as soon as power my car the cutout opens and it wont close when pressing the toggle switch.
Old Mar 12, 2006 | 04:33 AM
MeanGreen97Z's Avatar
Re: Electric cutout problem
The motor is burned out. Happened to mine and as soon as I shut the car off it closed up....
Old Mar 12, 2006 | 10:34 AM
Im not sure that the motor is burned up, because I manually closed the cutout up and it opens like a charm. everytime But it just wont close. I did alter the wiring on my device. I was short one wire so what i did was cut the adaptor off the end of it and just run black and red wire all the way from the switch to the cutout.Would this mess me up?
Old Mar 12, 2006 | 12:52 PM
Got a picture of how you wired it? Can you snap one?
Old Mar 12, 2006 | 02:20 PM
I acutally figured it out but I have one problem still. How I wire dit was like this I cut the adaptor off the end of the motor and exposed the red and black there then after that I ran the black and red wires into the car into console where the cig lighter goes then I ended up connecting the orange from the cig to the red wire and the black form the cig to the black wire and this makes my cutout closed if I switch the wires around and make red to black and black to red the cutout opens How do I incorperate the switch? Where does it fit in so I dont have to hotwire my cutout each time?
Old Mar 12, 2006 | 02:43 PM
what kind of switch do you have? Is it a 3 pin?
Old Mar 12, 2006 | 02:44 PM
Radio shack has all kinds of switches. Tell them what you need and the tech=o geeks there will hook you up.
Old Mar 12, 2006 | 05:52 PM
I have the switch that comes with that comes with the q-tec cutout its the one with an led on the tip . Push it one way it turns green the other way it turns red. One color for open close i think.
Old Mar 12, 2006 | 06:47 PM
there is a relay in that harness I believe. I really need to either see the wiring diagram or a picture of the wires.
Old Mar 12, 2006 | 08:28 PM
Thanks for replying Meangreen I figured it out and it is awesome I love not having to crawl under my car to unleash the beast.
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
stanghunter211
Aug 29, 2002 03:04 AM
