replacing the lifters
Old Mar 11, 2006 | 11:16 PM
KillWhitey's Avatar
I have a terrible tick that is coming from the drivers side of my motor. Tomorrow I am going to tackle the lifter swap.
Do yall have any tips or tricks that might help me along the way.
I already have the new lifters soaking in oil
I got the intake manifold gasket kit from felpro
A case of cold beer
fresh can of copenhagen
Chime in if i left anything off the list
Any help would be greatly appreciated
Tim
Old Mar 12, 2006 | 12:14 AM
WhiteThunderZ28's Avatar
Re: replacing the lifters
are you sure its not an exhaust leak? It is nortorious for a ticking sound to be coming from the drivers side, even my camaro does its.
All you might really have is bad header gasket or where the header and y pipe meet gasket.
Old Mar 12, 2006 | 01:43 AM
Fastbird93's Avatar
Remove the Intake Manifold/TB/Fuel Rail assembly as a single piece. Saves time.
Set your valve lash with the manifold off, it lets you get a really good bead on things.
Nice thick bead of RTV at front/rear block rails. Don't want any leaks.
Old Mar 12, 2006 | 09:16 AM
KillWhitey's Avatar
Will i need a special tool for the fuel lines?
My gaskets came with rtv got that one covered
Old Mar 12, 2006 | 09:17 AM
KillWhitey's Avatar
I know it is not an exhaust leak cause when I did lt headers, it was making the same sound before and after
Old Mar 12, 2006 | 09:19 AM
396D1SS's Avatar
yes you will need a tool to remove the fuel lines. If its a ticking lifter have you tried tightning that valve a little ?
Old Mar 12, 2006 | 10:53 AM
KillWhitey's Avatar
Yes but not as loud.
Old Mar 12, 2006 | 10:58 AM
KillWhitey's Avatar
If I do not have the fuel line removal tool is there a way I can remove the lines without it?
Or do I have to pull the fuel rails and set them aside instead?
Old Mar 12, 2006 | 11:08 AM
KillWhitey's Avatar
Does anybody have a link to a guide that I could follow?
Old Mar 12, 2006 | 11:25 AM
Fastbird93's Avatar
No problem. Just unclip the fuel lines from the retainer on the strut tower, take the rails off the manifold, and just twist them up and back and lay the rails on the windshield. No worries.
Old Mar 12, 2006 | 01:39 PM
Stoopalini's Avatar
Most autoparts stores carry the fuel removal tool for little $$.
If that's not an option, you can take the rails off instead, like the previous poster said. If you do take the rails off, you may want to look at replacing the injector o-rings; depending on how many miles are on them.
Thomas.
Old Mar 12, 2006 | 03:07 PM
KillWhitey's Avatar
I got it all apart. I am just waiting on my new pushrods that my bro is going to bring over. I got it all cleaned up and Will probably finish tonight or in the morning.
The O rings came in the gasket kit
rtv
O rings
egr, tb, and manifold gaskets
Old Mar 12, 2006 | 03:28 PM
KillWhitey's Avatar
any tips on how to adjust the rockers?
What methods have yall used?
Old Mar 13, 2006 | 06:02 PM
KillWhitey's Avatar
I just finished up. It runs better than it ever has.
Thanks for all the help
Tim
HectorM52
Jul 30, 2017 11:46 AM
Sauced
Apr 12, 2015 10:18 AM
dfarr67
Apr 10, 2015 07:44 PM
jj_burchiel
Mar 5, 2015 07:05 AM
jayblev95
Dec 1, 2014 06:55 AM
