View Full Version : LT1 Based Engine Tech
- Just got my 96 z28
- Someone HELP
- Bought a camle for OBDI and need some software...
- Car still overheating after new radiator...
- Blue smoke now...
- Help Quick!! Couple of questions before dropping the tranny out of car...
- Best Electric Water Pump
- ATTN: Guys with 'verts...
- Oil leak question....
- Valve cover gasket question
- Why is my car feel slow out of the hole??
- Tranny tech question?
- Part Number Question
- Question regarding the Canton oil pan for the LT1
- O2 Extensions w/ Mac Headers or not?
- How to drop this damn driveshaft?!
- Have a stupid question about a good topic
- what causes rear brakes to click
- Hal QA1 Front Adjustable Shock Problem??
- header longtubes and inspections
- Power Steering diagnostic
- Long black support along side the driveshaft?!?
- Break In Procedure
- Placed internet order 3 wks ago, no word yet, what should I do???
- LCA relocation after SFC install?
- car dies everytime passanger front wheel hits water puddle
- Do they make a Y pipe for BBK shorties?
- Head liner sagging
- Anyone ever experienced this with their Tranny?
- $2000 to spend on speed
- SLP flywheel owners please read.
- Transmission
- Average / Best STOCK LT1 Times
- projected HP
- What guages should i get
- HELP! 4l60e???
- help!! exhaust
- 3.3 degrees of KR at idle...
- mileage on H and Z rated tires???
- Can you all look over these data logs?
- Quadrant Driver???
- HELP! Just installed 52mm throttle body and it's constantly reading 1% throttle?????
- Whats the best cam for me?
- Dome light wont go out????
- What To Do For A Rear?
- Its Fixed
- need some tuning advice!!
- $300+ to spend
- ordered 2800 torque converter
- running rich! how much does it affect...
- Part numbers for 1LE fog light delete kit?
- Holy ****! This Has To Be By Far The Worst Thing Racenet Has Done In A While
- What mods to do next?
- How hard is a 3.8L to LT1 swap in a 98
- Anyone want to try out some heads I'm porting?? there free, you just pay shipping
- TB coolant bypass question
- XE 230/236 anyone got numbers with this cam??
- Disconnect the clutch master cylinder pushrod? HELP QUICK!!
- Cam Install, change oil pan gasket
- 93 vette LT1 ...gen1 or 2?
- rebuild help needed in dallas/mesquite area
- fel-pro gasket #2001
- Strut removal 93z
- Need a M6 Tranny in California
- Whos familiar with stock 96 SS Exhaust?
- i need someone to run a carfax for me
- tranny problem
- How long did you wait to do wot after cam install?
- part number for belt for mac underdrive pulley
- Who makes a Tall center bolt valve cover
- Heat shield ?s
- Ive about had it with this TPS and TB!!!
- bfg drags
- How many teeth on a stock 94 flywheel
- High RPM's on stock bottom end
- Cam Help !!!!?????
- What brand gear do you run?
- Ever a 400BB
- What kind of ramps should i buy?
- Which Clutch???
- EGR two wire connection question?
- Chip for 93 T/A
- advance timing
- Need cam suggestions for a stroker please
- 93 timing chain?
- Set me up with a clutch! (did a search)
- Where to get just a clutch disc.
- flowmaster sounds bad
- any predictions on dyno #'s please
- DTC 29 and 32 - EAS electrical system failure??
- Accell plug wires
- Part #'s for OEM springs
- o2 sensor replacement
- Help!! Heard pop
- True WS-6 Verification
- need help poping through the exhaust.
- Knock sensor. AC or DC ?
- how do you buy tunercat
- Lowered Cars...New LCA needed?
- Deep Throaty Exhaust?????
- radiator? shoebox
- pruge valve
- Dyno Graph for CC306
- 350 RWHP would it equal low 12s, depending on the driver of course?
- Can the Opti do this
- Heads and cam guys...
- Need help on changing plugs and wires
- What Are The Symptoms Of A Bad 02 Sensor?
- afgs*1.1=rwhp ?
- Opti help...fixed it or not fixed it?
- clutch slave cylinder
- Alright guys, A track Virgin Here.What rpm do u 3000 Stall guys launch at?Hal Settin?
- Muffler in series?
- SLP Headers Plug Access
- Difference between air/no air cats?
- heading to the track for the first time
- !!!read Here!!!(why You Shouldn't Use An Lt4 Km)
- How do I adjust and test my TPS?
- How much effect do RESONATOR TIPS have on exhaust sound???
- Backpressure kills performance?
- Is 450 rwhp possible?
- Fast Toys
- Th400 vss question
- Installing gear?
- headers and emmisions
- Welding cylinder head intake ports
- How do you change your oil?????
- Hooker Catback
- rim size
- What is this black box on drivers side, underneath the hood alignment post?
- Alright I need some more opinions on my headlight problem...
- What does the Combination Motorsports "Cam package" Consist of, and where are they?
- Have A Transmission Question.
- How do you test sparkplug wires?
- Don't gut your cat..
- Which Gears to go with?
- which cam for this setup?
- top speed of a Th350/3.23/26.5 tire?
- I'm bolting them on... GTP's..
- Got the money to do a cam swap. Did i make the right choice?
- need help with my moser 12 bolt
- Need some help on part #'s. Doing a cam swap on a 97 TA.
- Tranny Cooler
- SLP Headers What's Wrong?
- Wtf goes in this hole Huge oil leak
- gear swap??
- Installed ES Poly Trans mount, now another noise???
- Ignition Coil Question
- Went for inspection; Blew motor.
- Exhaust ?
- Solved my stumble
- ? Proof ? Mufflers
- Hit the dyno today
- Slipping Tranny?
- Part# for EVAP purge vacuum switch?
- Cutouts
- Poll: What's everyones choice for a 6 speed shifter???
- K&n Cai?
- TPS code PO122?
- Which Clutch should I use?
- dumping exhaust before axle
- Ford 9 Inch for 1000? Where? WHo knows About this?
- How Long does a stock clutch normally last?
- help!! lt1 gear swap
- Tach Light??
- tranny shop
- HELP! #1 header tube hitting steering linkage under accelleration
- how to disable the aigbag light ?
- 1995 TA, cd/dvd player install help
- Hard Start Knock
- fireing order???? 97 opti
- tb qustion
- Does this sound like a dead opti or not?
- headers whats your advice
- idling rough
- Ram or Zoom clutch
- 1993 Trans Am
- ET Streets
- How many O2's!!
- Which XE cam for my 383 ?
- Newbie needs help with A/C
- Which Header Give The Biggest Hp Gain
- Best place to put B&M tranny cooler??
- 30# or 36# injectors??
- Optispark Firing Picture
- exhaust help
- Which OVC wire set?
- Car throwing code
- fbody.com gone?
- ARP head bolts and LT1 torque specs
- parking brake removal procedure
- Area Under the Curve
- springs
- Lt4 Km
- Gonna kill my car!!!!!!!!
- What kind of gains from Mac headers?
- AC compressor
- Aftermarket tach's
- Where can i find????
- Kumho Excsta MX tires
- Questions about some drag tires
- Need to fix my OIL leak - Got advice
- one last offroad pipe question anyone with shorties might be able to answer
- Throwing Code 11 - Indicator Lamp Malf - Need Advice
- common LT1 problems
- Is this correct (hotcam related)??????????
- MAC Headers & Stock Cat
- eibach or hotchkis springs??
- Jet Hot Long Tube Users:
- any header gasket? help
- Follow up on LT1 Starters. Which one?
- where to buy felpro's?
- broke coolant temp censor
- I have starter questions.
- Roller Rocker
- Headlight problems?
- Question about shocks and struts? Where to buy?
- catalytic converter problem?
- Chrome rims and dyno?
- Opti cap & rotor question....
- Gains from ThrottleBody?
- no answer
- cam kit?
- Changing the Oil
- SLP LT4 PP/clutch....opinions please
- 1995 Mac Header Question?
- What fuse or wires can shut off red idiot dash lights?
- Resetting ABS Light
- Does anyone use their Nitto 555R's for daily driving?
- 700r4 in 94 ????
- Porting heads and a cam??....
- Help please.....mysterious miss between 4500 - 5000
- how much for cam install?
- l98 low end vs lt1
- accel/LPE SuperRam intake
- As&m Cai?
- Lt1 to Ls1 intake airbox assembly
- stock flywheel can't be turned?
- trans temp gauge
- Guys with Mac Headers inside please, ? about wires
- Anyone converted to a 98+ Instrument Cluster Dash? Is it doable?
- Custom Cut your wires (if you were to replace Taylor OVC)
- New Summit racing Long mufflers
- Spark Plug Gap
- car revs without touchin gas
- LT-4 clutch?
- Borla catback with new muffler?
- ls1 clutch on Lt1
- Oil hookup and water hookup?
