93 vette LT1 ...gen1 or 2?
Old May 13, 2003 | 09:36 PM
tweetybirdy's Avatar
Is the engine in a 93 Corvette a first generation or a second generation LT1, and what is the difference, just flow?
Old May 13, 2003 | 09:38 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
i think there is only one generation of the gen II (LT1)
all blocks were cast 327 as far as i know
Old May 13, 2003 | 09:39 PM
neil350's Avatar
Gen II, Vettes got the LT1 in 92, the prior motor to that was the L98 Tuned Port Motors.
Old May 13, 2003 | 09:43 PM
so a 93 LT1 block would work?
Old May 13, 2003 | 09:48 PM
IrocManiac's Avatar
I believe the difference is the vette had 4 bolt mains and the f bods have 2?
Old May 13, 2003 | 09:51 PM
treyZ28's Avatar
92-96 vette blocks and 93-97 f-body blocks are the same with the exception of the 4 bolt mains of the vette to the 2 bolt mains of the f-body
"work" is a general word....
work in what? using F-body internals? building a 383? dropping it off a roof and killing your ex-girl friend when she comes by with her new boyfriend?
gen I 350's are from about 66 or 67ish to 92(93 in f-bodies)
Gen II is the LT1 in the f-body from 93-97 and vette from 92-96 and B-bodies for a short while.
although realisitly i'd say the TRUE gen I ended around 84 or 86 when they went with a 1 piece rear main seal and changed all the bolt patterns in later 80s.
the late 80s/early 90s gen I really has more in common with the gen II than it does with the rest of gen I.
internals are pretty much interchangable (although there are balancing issues) and there are more similiraties....
i'm not 100% on the dates
Old May 13, 2003 | 09:54 PM
well that clears things up, thanks, tho i doubt my ex will be to happy when i finally get around to the dropping
neil350's Avatar
Thats about it, the motors them selves are the same. Block in one will work in the other.
Old May 13, 2003 | 10:10 PM
2MCHPSI's Avatar
There was a 350 engine called the LT-1 back in the 70's which is totally different than the LT1 from 92-97
So the 93 would be the 2nd gen LT1 engine from GM
Old May 13, 2003 | 10:11 PM
treyZ28's Avatar
good call
but one is the LT1 and the other is the LT-1
Old May 13, 2003 | 10:20 PM
2MCHPSI's Avatar
Do I hear an echo??
Old May 13, 2003 | 10:22 PM
treyZ28's Avatar
Do I hear an echo??
:::quickly recovers to his defense after being internet bitch slapped to the floor::::
he did say
So there is only ONE generation of the LT1 all with casting number 327
Old May 13, 2003 | 10:31 PM
2MCHPSI's Avatar
LOL
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
smokin25th
Jan 1, 2015 09:06 AM
BLUETOPTA
30
Sep 18, 2002 12:22 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
stars1010
Jul 17, 2002 04:36 PM
