What is this black box on drivers side, underneath the hood alignment post?
Towards the front of the car, right underneath the screw post that raises or lowers the front edge of the hood.
Naw, not that one, if your looking into the engine bay from over the drivers side fender though, its to the left and more towards the front of the fuse and relay box. Its got 2 connections going into it I think.
It’s the “Headlight Controls Module”. It has all the logic for operation of the headlights. It senses back EMF to tell when they are closed or open and cuts power to the motors accordingly.
Originally posted by Bud M
It's the Firebird driver protection box. It lowers hp by 20%. That's why Camaros are so much faster. Leave it alone, it's for your own good.
I wish I had one of those in my car so I could disable it
!Dave
Be careful where you relocate that box to when you get the CAI, mine was too close to the fender and got wet. Water leaked down between the fender and the hood and soaked that module.
Guess what? headlights didn't work and that "dealer only" black box cost $380 to replace.
Okay, now this could go along with my other question of why my regular headlight beams don't work, but my high beams do?? When I turn on the headlights, the voltage kinda bounces all over and the headlights don't pop up. When I click the highs on though, they go right up and work fine.....anything to do with this box perhaps?
Never moved it, but the car was hit there. Not super hard, the tire was turned to the left and took most of the impact. The nose and fender only had to be repainted. I've been wondering if this was to blame. Is there a way to check the box?
I had a car that was hit in the drivers side front. The module had a small crack in the casing (just enough for moisture to get in) and after a year or two the headlights started doing wacky things.
They are actually not very expensive to replace, $300 form the factory but only $15 or so from a salvage yard. (I feel sorry for anyone how actually bought one from the factory
Jul 4, 2005 05:00 PM
Patrick Davies
Aug 8, 2002 08:30 AM
