SLP Headers What's Wrong?
Old May 12, 2003 | 09:56 PM
ZYALATER's Avatar
I had SLP headers installed and I don't feel any difference.
If any change, I would say the car feels weaker.
Shouldn't I feel a good gain? I didn't expect it to rip the
seat bolts out of the floor board, but my car might be slower.
I believe I have a small leak at the y-pipe flange.
Could this be a problem?
Maybe I'm getting false knock, from the leak and louder exhaust?
Somebody told me I needed to reset my PCM, is this true?
If so how?
Any suggestions?
Old May 12, 2003 | 10:19 PM
ZYALATER's Avatar
Anybody???
Old May 12, 2003 | 11:24 PM
Z_Maniac's Avatar
You might wanna invest in an LT4 Knock Module as you can be getting false knock and definitely can rob you of power. As far as resetting your PCM just unhook your battery and let it sit for atleast 15 min and hook it back up and should be good to go.
I would double check to make sure all exhaust leaks are fixed.
Old May 13, 2003 | 02:38 AM
Ryan 97 Ram Air T/A's Avatar
Don't know about you being down on power, but sealing the driver's side collector on my 97 was a nightmare. If yours is leaking it's going to burn through the gasket quickly. In the end if you have a 1/4" ds collector flange, call SLP and order the 3/8 flange and have someone weld it on. I tried every trick in the book and nothing worked until I replaced it. They should be burned at the stake for selling headers with 1/4" flanges.
Good luck man, besides the hassle they have been, I think the SLP headers look good and perform fine.
Pig Pen
Parts Wanted
Apr 30, 2015 08:41 AM
jim88iroc305
Aug 13, 2002 09:24 PM
ScottZ
13
Aug 2, 2002 11:45 PM
Wilson
Jul 21, 2002 05:08 PM
