Hard Start Knock
Old May 12, 2003 | 05:35 PM
AlmostfastLT1's Avatar
Exclamation Hard Start Knock
When I go to start the car when it has already been running and the motor is warm, the motor will crank alittle slow and will start with a hard start. You can hear a piston slap or knock. I did have problems with my opti, but i just replaced it and it did help alot. Also the wiring harness to the alternator needed to be replaced because it was not charging the battery and it was cranking real slow before i replaced that. Any ideas or help.
Thanks Mark Tisdale
Old May 12, 2003 | 05:39 PM
chasmanz28's Avatar
Re: Hard Start Knock
Thanks Mark Tisdale
While the fuel injectors have a distinct tapping noise (usually under higher throttle), at a light load and low speed there seems to be "piston slap" on some people's cars. There doesn't seem to be anything in the service manuals. Most dealers seem to acknowledge the problem and say it's normal, which it seems to be. For some reason, the pistons shrink enough in the cold weather so as to "slap" around a little. Once the car warms up, the noise should go away. This is also a noticeable quirk of the LS1. Some peoples cars is it more noticeable than others.
useally the piston slap comes when you first start the motor, i get that once in a while when its cold outside, but if it warms up i never hear it, but your saying when its warmed up it slaps, dont know dude but that doesnt sound good, im sure guys will help you out on this one
Old May 12, 2003 | 05:54 PM
Exclamation
Yea the knock will only will happen when the car cranks slow and it will start hard with a knock.(Only when the car has been running). But when the car it cold the motor will crank very smooth. Also when the car is running it will not knock under accleration or idle, car has no problems.
Old May 14, 2003 | 10:30 AM
TTT
Old May 14, 2003 | 12:00 PM
LWillmann's Avatar
On my old 82 Camaro, if the motor was warmed up and I shut it off, the starter wouldn't want to turn it over, and when I did get it started again, I would heard a "knock".
It turned out to be my starter...
You might try replacing the starter and seeing if that doesn't fix it.
HectorM52
Jul 30, 2017 11:46 AM
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
jayblev95
Dec 1, 2014 06:55 AM
