Lowered Cars...New LCA needed?
Old May 13, 2003 | 12:51 PM
Raider Z28's Avatar
I recently lowered my 96Z28 with the eibach Pro-kit and also installed the Koni SA's.
Please educate me as to the neccisity to replace the LCA's and add a Panhard Rod.
Old May 13, 2003 | 01:00 PM
norcalstreet's Avatar
The stock lower control arms are simply pressed steel and are subject to flex. Upgrading to some lower control arms prevents this flex and puts more power to your wheels.
You should also get some relocation brackets since you're lowered. I would recommend getting boxed lower control arms and weld-in relocation brackets. Checkout http://www.norcalstreet.com for some pricing on these or shoot me an email at mike@norcalstreet.com
An adjustable panhard bar is needed to align your rearend.
Old May 13, 2003 | 01:01 PM
LWillmann's Avatar
My understanding is that you don't need to replace the LCAs, but rather install relocating brackets to make up for the drop in suspension.
The pan hard rod helps to stiffen the side to side motion of the car when turning. The stock one isn't as strong as most aftermarket units. Changing the pan hard rod can help keep the car from rubbing tires in the wheel wells.
Old May 13, 2003 | 01:23 PM
jer4251's Avatar
i just bought my 97 SS 2 months ago, it has the ebiach springs. with my car comming with a factory suspention package, do i need to do the same with the reloactions? i'm not sure if the guy i bought it from did it or not. but he knew quite a lot about lowering cars. how can i tell if it has already been done?
Old May 13, 2003 | 02:34 PM
http://www.bmrfabrication.com/instru...b-cablemod.jpg
This is a picture of what the BMR relocation bracket looks like installed. These are the bolt in type. Just look at your control arms and the relocation bracket will be attached between the control arm and rearend.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Jan 31, 2015 07:29 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
