What does the Combination Motorsports "Cam package" Consist of, and where are they?
Looking to do a cam swap. Just checking out all avenues before ordering. What does the Combination Motorsports package consists of? And where on the web could I see a break down list?
N218K
Comp Cams Xtreme Energy 218/224 Cam .528"/.536" Lift
Comp Cams Pro Magnum 1.6 Rocker Arms, Self Aligning
CM611 Valve Springs
CM126 Chromoly Retainers
CM007 7 Degree Hardened Locks
Description: This cam is great for your daily driver, with a great power band. Mild manners, but not too tame (you'll definitely know it's got a cam in it) make this cam a great all around performer. Designed for naturally aspirated engines.
RPM Range: 2400-6000
N224K
Comp Cams Xtreme Energy 224/230 Cam .536"/.544" Lift
CM612 Valve Springs
Description: Our most popular cam, and for good reason. This cam makes great power everywhere, but really shines in the midrange and top end. Makes excellent power with stock or ported heads. Not too wild for the street, but not as mild as the 218.
RPM Range: 2800-6400
S224K
Comp Cams Xtreme Energy 224/236 Cam .536"/.555" Lift
Comp Cam Pro Magnum 1.6 Rocker Arms, Self Aligning
CM612 Valve Springs
Description: Designed for cars using nitrous or a supercharger, this cam will really help your power adder car breathe. Our most popular nitrous and supercharger cam, and for good reason. It makes amazing power even without the nitrous, and when you hit the button....look out.
And now to what you've all been waiting for...price. We won't keep you waiting.
$578.00
You can subsitute any of the Comp Cams camshafts on our website for the same price, these are simply our most common cams.
CM611 Valve Springs
N224K
CM612 Valve Springs
S224K
CM612 Valve Springs
$578.00
oldschool
Feb 9, 2016 09:21 PM
