idling rough
Old May 12, 2003 | 04:55 PM
rotoruter2001's Avatar
idling rough
Ok. I was out for a leisurely drive and found a viper. Needless to say we played for a bit. However, later that night coming home I noticed my car idling a lot rougher than before. The RPMs are exactly where they should be, but the car vibrates more and it doesnt feel good. Once I am in gear and driving it is fine, but at a stop it is bad. Any ideas?
Old May 12, 2003 | 05:16 PM
chasmanz28's Avatar
Re: idling rough
you have to do the basic stuff first, fuel filter change, clean the inside of the tb, check wires, and plugs, if you do all of that and you still have problems then come back.People have reported that replacing the factory spark plugs with better ones like NGK TR55s and wires smoothened out the idle a bit.
Old May 12, 2003 | 06:09 PM
slashz28's Avatar
CHECK YOUR OIL make sure youre not running low on oil, dont ask how i know
Old May 12, 2003 | 09:06 PM
have oil, replaced air filter, cleaned MAF, wires n plugs are new (4 months old) and not worn, tb cleaned all this and still doing it but only when idling. It scares me. I am going to change the oil tomorrow and see if it helps its been 3000 miles.
Old May 12, 2003 | 10:21 PM
chasmanz28's Avatar
the Lt1's do idle a little ruff, as long as its not a miss your ok
Old May 12, 2003 | 11:28 PM
i have had my car for a while, this is not the standard rough idle. this is the something is not right i hope it doesnt blow idle.
Old May 13, 2003 | 12:44 AM
slashz28's Avatar
yeah, you changed your oil, but did you check now to see if its full or not?? last year when i lost half the oil in my engine thats exactly what my car was doing. shaking violently at idle. very well could be something else but you lose nothing by checking again hth
Old May 13, 2003 | 01:01 AM
Fatdog's Avatar
Cool Fatdog
Wires.Change the coil wire first.Plugs.Change the plugs again.I killed a Viper to 60mph,he is still waiting for me somewhere,as he left my cold.Hope this helps.
Old May 14, 2003 | 11:30 PM
well it seems to correct itself at times. Sometimes is idles rough other times it doesnt. Thus, I dont think it is ignition related. I was told to check the vacuum lines, and then use fuel injector cleaner. Think this is a good idea? If so what type of cleaner?
Old May 14, 2003 | 11:42 PM
atljar's Avatar
Mark-
Bring it on over to my house one day, and we can seafoam (this stuff works for everything) it, and ill log it on the computer and see what its doing.
just give me a call
708-1492
Boss002
Jan 20, 2016 12:17 PM
Firechicken350
Aug 30, 2015 06:59 AM
michaelzilinski
Jul 31, 2015 08:41 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
