Quadrant Driver???
Old May 14, 2003 | 12:52 AM
95z115's Avatar
Quadrant Driver???
My 1995 Z28 Automatic transmission was making a wierd noise at its normal shift point when the car was floored and it didn't shift into the higher gear unless i letoff the gas. I had the car diagnosed on the computer, and it alerted a problem in the transmission, the quadrant driver. What is this, how much is the part, and is it a hard thing to replace? Thanks
Old May 14, 2003 | 01:00 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i would like to know this as well...
Old May 14, 2003 | 08:22 AM
Need the specific DTC. Sometimes people interpret them wrong.
Old May 14, 2003 | 10:42 AM
95z115's Avatar
Sorry I dont know the exact code, the garage ran a diagnostic and he just told me that. He didn't do that type of work but reffered me to some people will do it. He said that a shop will re-diagnose it when they fix it anyway because they dont just take other peoples words for it as far as what codes came up. He just told me quadrant driver. So what do I need to fix and what does it entail?
Old May 14, 2003 | 01:41 PM
That's why the specific code is needed. AFAIK, there are no codes for quad drivers on a 1995. Last mention of them is on a 1993, so the explanation is ambiguous and does not point in any direction to tell you what the problem is.
There are drivers used by the 1995 pcm, but the code would be specific to what was really seen as a problem. The 1993 just said "quad driver" and you had to figure it out among several things it could be.
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
240ssLs3
Jul 13, 2015 05:06 PM
Boss002
Jul 9, 2015 03:33 PM
