Need cam suggestions for a stroker please
Old May 13, 2003 | 04:41 PM
big dave's Avatar
I'm in the initial stages of a 396 build-up and unfortunately one of the things I have to be concerned about in this state is emmissions. I've heard that cams as large as the cc306 can be made to pass in a stroker but I think that may be a bit too large. The motor should be around 11.0-1 with my stage 2 ported heads. Driveability is somewhat of a concern also. I've considered the gmpp 846 cam mainly because it has the same duration as my present cam (222/230) but more lift (54?/56?). Can you guys tell me what cam or cams you have or are using and how is streetability? What kind of power would it make behind an a4? I don't know if this meets advanced criteria but any help/suggestions you can give will be greatly appreciated.
Old May 13, 2003 | 09:59 PM
kmook's Avatar
Advanced Tech Moderator
Hey Dave, yeh this does really fit LT1 Forum Specs. Moving for you...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Feb 17, 2015 08:12 PM
Killer94z
Jan 13, 2015 12:06 PM
