Are u suppose to reuse Flywheel bolts once taken off?
Old Jun 2, 2004 | 12:17 PM
ZDriver96's Avatar
IM rebuilding my engine... and the fly wheel is off.. My friend told me that your not suppose to reuse the flywheel bolts.. is this true? Mine have 100k miles on them.
Old Jun 2, 2004 | 02:53 PM
1 Nasty Bird's Avatar
Ive reused flywheel bolts a couple dozen times, if your really worried a set of ARP bolts are probably under 25 bux.
Old Jun 2, 2004 | 03:15 PM
Bilmind's Avatar
If they look fine, I would say reuse them...
Old Jun 3, 2004 | 12:23 AM
OBE1 95Z28's Avatar
Cheap insurance to save you legs.
Old Jun 3, 2004 | 12:40 AM
Bud M's Avatar
ARPs are about $12, that's what I used
Old Jun 3, 2004 | 05:40 AM
Amped96's Avatar
Hmm...I didnt even think of replacing mine when I did my clutch swap. My car has over 120k miles on it and all is fine.
Old Jun 3, 2004 | 06:00 AM
Don 97 SS's Avatar
I understand that these bolts are reusable, but I generally don't take chances with critical bolts on a performance vehicle. I replace them with ARPs.
Old Jun 3, 2004 | 07:11 AM
Mystic95Z's Avatar
Not worth the risk to reuse the old ones when I nice set of ARP's can be had for ~10 bux. The only thing that pissed me off about them was that I had to go out and buy a 12 point socket to fit them...
-Tony
rskrause's Avatar
Moderator
I am not inclined to scrimp, but I have reused them on many vehicles without a problem.
Rich Krause
Old Jun 3, 2004 | 08:05 AM
bad95z28's Avatar
maybe your friend is thinking about head bolts
Old Jun 3, 2004 | 08:07 AM
Kryckter's Avatar
Some say re-use and some say dont. Either way it really doesnt matter. It would be good insurance to go ahead and change them out but many people including most transmission shops will jsut re-use the old ones and never see a problem. Its up to you.
Old Jun 3, 2004 | 08:59 AM
LameRandomName's Avatar
In theory, any bolt that gets torqued to a particular spec should not be re-used.
In practice, lots of people re-use them.
Still, it's not a lot of money to buy new and never have to worry, is it?
Old Jun 3, 2004 | 10:56 AM
BadAssed93Z's Avatar
is reusing head bolts a problem?
Old Jun 3, 2004 | 11:28 AM
jkipp84's Avatar
Not recommended from what I've seen, however I did reuse mine last time I took the heads off (~2 years ago) with no problems. I got a set of ARP's from Summit for when my heads get back this time though. They're only $50 or so..
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
