rocker lash setting poll
Old Jun 4, 2004 | 09:37 PM
mobleman's Avatar
Just curious,
For those of you who have installed a cam and rockers, how many of you re-adjusted the rockers shortly after running the car? And, did you notice a difference?
Old Jun 4, 2004 | 10:48 PM
PoorMan's Avatar
1/2 past; never touched them again.
Old Jun 4, 2004 | 11:15 PM
Kory 88 Iroc Lt-1's Avatar
I do mine 1/2 past as well. just bring up tdc on #1 and follow the book then bring up tdc on #6 and finish. I have no problems with this method.
Kory
Old Jun 5, 2004 | 04:36 AM
jkipp84's Avatar
I went ½ with Crane lifters. Apparently you barely have to use any with R's though...
Old Jun 5, 2004 | 08:25 AM
mobleman's Avatar
I have the Pro Mags, and initially adjusted them at 1/4 past snug while putting the engine back together. Was wondering if anyone readjusted theirs shortly afterwards after running the car a few times and getting some heat cycles into the setup
Old Jun 5, 2004 | 09:25 AM
RamAir95TA's Avatar
About 1/16 turn past zero lash with Comp Rs. Any more and you risk collapsing them.
Old Jun 5, 2004 | 10:26 AM
bunker's Avatar
acctually with Comp R's you don't risk collapsing them, problem with going tight on them is at high RPM the plunger will extend full like a solid lifter is basicly, this will keep your valve from closing all the way so either you valve float or bend some valves/pushrods when piston hits valve.
Old Jun 5, 2004 | 11:08 AM
mobleman's Avatar
Great info everyone.. I'll probably try to adjust them here tonight or tomorrow while idling before I take the car off the ramps..
Old Jun 5, 2004 | 11:29 AM
ibanez6rg's Avatar
Oh so not true. I went 1/4 with my Comp R's. Shoebox suggests 1/2 turn with them, but also agrees 1/4 should be fine.
Old Jun 5, 2004 | 04:20 PM
gb95zconv's Avatar
I go 1/4 turn past lash, lock um down, and never have had to readjust them. I prime the engine prior to finding zero lash.
Old Jun 5, 2004 | 04:38 PM
bunker's Avatar
Umm.. It is true, sorry bud but if you're going 1/4 turn then your obviously starting to loose power at high RPM, try 0 lash while car is running & see the difference for your self, anything past 1/8th of a turn & even 1/8th at times my car would rev past 6200rpm or so & would hit a wall.
Old Jun 5, 2004 | 05:36 PM
mobleman's Avatar
Cool I can find out for myself then,
I'll leave them as is for now and I'll readjust them afterw driving it for a week or so and see if I note a difference
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
alphaauto
Jan 23, 2015 07:42 AM
