Help with plug and wire change needed
Old Jun 4, 2004 | 01:41 AM
RedHottG2's Avatar
The last two times I changed plugs and wires it was a PITA of course. What are some tips and tricks to make the job go a little easier this time around, Any suggestions at all ? Give some secrets you might have to to get this done a little quicker. If that's possible lol.
Old Jun 4, 2004 | 02:02 AM
25thBird's Avatar
Try getting the hard ones from the bottom. The last 3 in the passenger side are easier from the bottom. The driver side can be done from the top, except for the last one maybe.
Old Jun 4, 2004 | 06:43 AM
94_Z28_guy's Avatar
Get the alternator out of the way on passenger side.
Old Jun 4, 2004 | 07:46 AM
sabre81's Avatar
something that helped me was having my AC deleted. And i couldnt get the plug closest to the firewall on the passenger side for the longest time. I eventually figured out if i twisted my left arm clockwise until my palm was facing out then went in to get the plug that way my arm fit down there enough to get a socket on there and get the plug out. Kind of hard to explain but it worked. Just try some different contortions with your arms and youll be surprised.
Old Jun 5, 2004 | 09:32 PM
Andrew04ME's Avatar
i dont see how you could get the passenger side wires from the bottom without removing the y pipe. I'm almost finished with my plug and wire change and i can say that its been a bitch.
Old Jun 5, 2004 | 10:23 PM
)2overt SS's Avatar
Definatly removing the alternator
Old Jun 5, 2004 | 11:44 PM
carlos64030's Avatar
Some of you may say that this is an extreme way of curing the plug and wire change issue...but I say get rid of the stock exhaust manifolds and upgrade to some longtube headers. Believe or not...that was my prime motivating factor for going with longtubes...the performance gains from them are just a bonus!
Old Jun 6, 2004 | 01:56 AM
RedHottG2's Avatar
I agree, the first job I did was on a manifold car and I hated it. The second car I did was on a LT car and it was a little easier. All the things mentoned here will be a big help. Thanks guys!!
Old Jun 6, 2004 | 02:27 AM
Compstall's Avatar
You don't have to remove the y-pipe. You can also take out the starter and be able to reach up in there too. Either way takes about the same amount of time, but I prefer taking out the starter. No rusted bolts to deal with.
Old Jun 6, 2004 | 07:50 AM
Jeff95TA's Avatar
It helps to be skinny like me.
Old Jun 6, 2004 | 09:16 AM
)2overt SS's Avatar
Starter is also a good idea...
I'm doing my LT install now.. and thats why I'm changing my plugs and wires
Old Jun 6, 2004 | 09:19 AM
RamAir95TA's Avatar
Ditto with the header install.
Jet Hots offer superb plug access...they almost pay for themselves. Even my old MAC headers had great access! Now I have the benefit of having great plug access and long tube headers.
Old Jun 6, 2004 | 09:35 AM
LT1Squirrel's Avatar
i take out the battery
PCLZ28
Dec 24, 2015 05:19 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
IRABuss
Sep 7, 2011 09:08 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
