What is fuel pressure supposed to be ???
Old Jun 1, 2004 | 09:59 AM
AZ2ENVY's Avatar
On a 94 LT1 at idle to WOT. Thanks
Old Jun 1, 2004 | 10:17 AM
hotrod18_69's Avatar
With the vac line off the regulator it should be 43.5 then the regulator takes over from there. But i can't tell u for sure what it would be around at idle or WOT. If its at 43.5 with vac line off then you should be good to go.
Brad
Old Jun 1, 2004 | 10:36 AM
BUBBA's Avatar
With the vac line off simulates WOT. Stock pressure probably between 45-47 at WOT. About 8 less with Vac line on.JMHO
Old Jun 1, 2004 | 11:32 AM
The spec is 43.5psi, +/-2.5psi, so at idle, no vacuum line, anything from 41-46psi is "OK". Connect the vacuum line, and the pressure should drop in proportion to intake manifold vacuum, or 6 to 8psi on a stock cam.
To measure the pressure at WOT, you have to be at WOT, max load/max rpm. The pressure should stay within 1 or 2psi of the "no vacuum" reading. Simply measuring the idle pressure without the vacuum line connected will not tell you if the pump can supply the demands at full load.
Old Jun 1, 2004 | 11:33 AM
AZ2ENVY's Avatar
Any other suggestions ?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
