exhaust leak
Old Jun 3, 2004 | 11:34 PM
pappasmerf18's Avatar
exhaust leak
can an exhaust leak screw up your timing at high rpms when wot but at a graduly throttle to wide open its ok what the problem i have an exhaust leak could this cause it.
Old Jun 3, 2004 | 11:56 PM
OBE1 95Z28's Avatar
Exhaust leaks close to the O2 sensors will screw up your air/fuel ratios. I believe the only thing to influence timing is your knock sensor; a lean air/fuel ratio could cause knock that would retard your timing.
Old Jun 4, 2004 | 12:22 AM
Punkillr's Avatar
running lean would cause knock, however if im not mistakin, bad o2 sensors tend to cause a rich condition???
Old Jun 4, 2004 | 10:59 AM
welling im getting the leak fixed to day and replacing the o2s as well
Old Jun 4, 2004 | 04:32 PM
turns out i blew my header gasket
F'n1996Z28SS
Aug 23, 2023 11:19 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Brake_L8
Jan 20, 2015 09:44 AM
