What times should I be running in the 1/4
Old Jun 4, 2004 | 12:04 PM
93transam1234's Avatar
I have a 97 formula
CAI,
LT Headers,
Custon 3 1/2" Y-Pipe into a Flowmaster,
3:42 Gears,
MADZ28 Programming,
Fresh Plugs and Wires
LCA's and Panhard bar
With a 2.1 60' what times and MPH should i be at.
I am going to the track tonight with the new Gears and MADZ's Tune and new tires.
Last time (and the first time ever) i ran once and got a 13.9 with a 2.2 60' at 100 MPH
Old Jun 4, 2004 | 12:15 PM
t-trimz28's Avatar
Are you going to be on drag radials, e/t streets, or radials?
Auto or 6 speed? (I'm assuming auto with new 3.42's)
My guess on street tires is low 13's
On e/t streets you could be in the high 12's with a good launch.
*edit* I just saw the 2.1 60ft. You will be in the mid-to low 13's
Old Jun 4, 2004 | 12:19 PM
Yeah i will be on brand new street tires (cant get a set of DR's yet do too $$) Iwont leave till i get a 2.1 or lower 60
Old Jun 4, 2004 | 12:58 PM
Tair's Avatar
I dunno what gears you changed from...2.73's, 3.23's? But I think you'll see about a 13.5 for your ET if you're changing from 2.73's to 3.42's. Madwolf tune is definitely worth a solid tenth and the gears will probably be worth 2-3 tenths considering good traction is attained. Good luck tonight!
Old Jun 4, 2004 | 02:03 PM
MarkyMark's Avatar
I pulled a 2.1 60 with cutout, 2.73gears, cai, and street tires and ran a 13.92 at 100.
You have headers and better gears as well as tune.
My guess would be anywhere from a 13.5 to a 13.7 at like 103 mph.
I would think if you can launch it right you should be able to pull a 2.0 or 1.9 60 and maybe a 13.3 or 13.4
You need some drag radials bad and then you can mash it off the line and pull some nice 60's and et's
Feffman
Oct 9, 2015 05:42 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
troywg
Sep 12, 2002 07:28 PM
