Catylitic Converters
Old Jun 3, 2004 | 12:26 PM
redz2810's Avatar
Question Catylitic Converters
I have a 1997 z28. My Cat just blew out and I need to replace it. It is the one that sits just about at the middle of the car. Not the two right past the manifolds. Anyways, I have done some research and found that because of the ODB-II, I have to put a certain kind of Cat on there.
Does anyone have any suggestions as to what kind of cat I get and wheather or not it will affect my emisson readings? I would like to go with a high flow cat but I am hearing that it will not pass smog. Remember I live in the foreign state of California.
Thanks guys,
RED Z
Old Jun 3, 2004 | 12:30 PM
I think if you go back and look, you will realize that your car only has two cats... the one in the drivers side of the Y-pipe is right up against the exhaust manifold, the one on the passenger side of the Y-pipe is down lower, under the hump in the passenger side floor. You could replace it with a stock unit, or get a high flow unit that is certified by the manufacturer as correct for your car/model - should satisfy CARB. If it were me, I'd replace both cats, to keep both sides of the engine in balance.
Old Jun 3, 2004 | 12:45 PM
redz2810's Avatar
any particular kind that you can recommend?
Old Jun 3, 2004 | 01:33 PM
americanmusscle's Avatar
Carsound, random tech, catco....
Old Jun 3, 2004 | 01:59 PM
redz2810's Avatar
I can use any one of these as long as they are ODB-II Certified right?????
Old Jun 3, 2004 | 04:48 PM
You can use them as long as the manufacturer tells you its the right cat for your car.
Old Jun 3, 2004 | 04:53 PM
phrozen's Avatar
make sure it has an EOD exemption number. You can then look it up on the C.A.R.B. website (www.ca.arb.gov I believe). If it does not have a CARB EOD exemtion number you will not pass the visual for smog.
Old Jun 3, 2004 | 05:53 PM
Bobs 94 TA's Avatar
I've been wondering... what does ODB stand for? An no, it's not Old Dirty Bastard.
Old Jun 3, 2004 | 06:03 PM
redz2810's Avatar
On Board Diagnostic! I just looked at the EO approved OBD_II Coverters and noe of them can be used on the Camaro. They are all for trucks. So does this mean I have to go to the dealer????
Old Jun 3, 2004 | 06:06 PM
Bobs 94 TA's Avatar
so I assume ODB I is 93-94, and ODB II is 95-97?
Old Jun 3, 2004 | 06:49 PM
bdc95ta's Avatar
The 95's have the obd2 connector w/ the obd 1 computer.
Old Jun 3, 2004 | 06:52 PM
2cub49's Avatar
try
www.cheapexhaust.com
NewsBot
Sep 14, 2015 02:02 AM
95craz28
11
Sep 12, 2015 07:47 AM
USN06
Sep 7, 2015 03:30 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Aug 5, 2015 08:35 AM
