STILL intermittent lack of power??
Old Jun 4, 2004 | 12:43 PM
NONO5.0's Avatar
This problem is REALLY irritating me! I've got a '95 T/A (mods below) and when I'm driving it.....if I give it gas it goes (pretty smoothly...no miss) but feels like something is holding it back....then all the sudden, it takes off. Its really weird. It 'seems' to get worse the warmer the car gets. The best way I can describe it is as if someone had a rope tied to it and then let it go all the sudden. I've replaced the plugs/wires/opti/ O2's on both sides. Could it be a bad injector or fuel filter? Any ideas
95 T/A converted to M6, 3.42's LT4 hotcam kit w/ ported/polished LT1 heads 2.00/1.56 valves 1.6 rr's, Moroso CAI, 52 mmtb, LT4 knock module, !CAT, TPIS headers, Flowmaster, electric cutout
Old Jun 4, 2004 | 02:13 PM
bdc95ta's Avatar
have u checked the fuel pressure? what was it?
Old Jun 4, 2004 | 02:54 PM
TenaciousZ's Avatar
I'm having the same problem your having and I know my rear brakes are dragging (I can hear them while cruising) i'm going to replace them monday but I have a feeling that this isn't the answer. I guess I'll also check fuel pressure.
Old Jun 7, 2004 | 03:58 PM
NONO5.0's Avatar
Fuel pressure was at 40 psi
Old Jun 7, 2004 | 07:49 PM
slopokrodrigez's Avatar
Do you still have an EGR? Maybe it's sticking. Common problem that gives performance problem.
Old Jun 7, 2004 | 08:31 PM
disco192's Avatar
There was a HHHUUUUGGGEEEE thread a while back regarding this issue.
There were many different problems that cause this. Some tried moving the ICM and coil. Some cleaned out the MAF. Some had clogged injectors. Some had bad IAT and MAP sensors. Some had intake leak. Some had bad fuel filters.
AlaskaZ28
Apr 17, 2015 08:54 AM
ad356
Apr 11, 2015 10:30 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Injuneer
Dec 15, 2014 09:36 AM
XtremeLt1
Sep 13, 2002 08:50 PM
