Question about stock manifolds
Old Jun 4, 2004 | 11:17 AM
ssbowtie1's Avatar
So next weekend, I will be swapping out Jet Hot lt's and reinstalling stock manifolds on a friend's car. He needs the stock manifolds on to pass emissions. He has stock manifolds but he doesn't have any of the bolts for them. Any one know if I can order these bolts and the part numbers for them, or threadsize and if I can just buy them from a parts store? Also, what kind of exhaust gaskets are needed, do I need a special kind or will generic header gaskets work (felpro 1406)? Thanks!
Old Jun 4, 2004 | 12:53 PM
Mtrhds94Z's Avatar
They are 3/8x16, and have a bunch of spacers etc on them[and studs on some etc]
I just looked at my stock manifolds, and it appears to me that 12 1" bolts [6 each side] would work OK [that won't mount that one alternator bracket tho]
As far as the gasket, on the 1406 FelPro, the end holes will be in the wrong places [the stock manifolds use the outer holes, and most headers use the inner holes on the ends]
FelPro M595585 have the outer holes cut out..
In a pinch, I'd say either set can be used, but it's a pain to cut the gasket for the bolt holes..
I have the M595585 on with my headers as we speak [got wrong ones] I just cut it out for the inner holes [both rearmost bolts are broken off in the head..] I had to use the inner holes, even tho the headers would allow either hole to be used..
Old Jun 4, 2004 | 01:28 PM
Red96Lt1's Avatar
Sucks to go throught all that work to lose power.
Old Jun 4, 2004 | 02:02 PM
ssbowtie1's Avatar
Is it possible to just use 3/4" header bolts instead of the studs/nuts/weird things that are on there stock? Thanks
Old Jun 4, 2004 | 07:51 PM
Mtrhds94Z's Avatar
I wouldnt.. but I use 1" on headers also[afraid to strip aluminum heads!]
Maybe get a s set of 1", then use for the headers when you reinstall them?
Mr Gasket has a set of 1" aoout 8 bux..
Old Jun 4, 2004 | 08:57 PM
ssbowtie1's Avatar
Oh ok...I was just worried that the 1" bolts might be too long. I guess not though. Thanks so much for your help
DirtyDaveW
Dec 1, 2016 05:37 PM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
spearous
Jan 12, 2015 11:03 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
