Header leak...?
Old Jun 1, 2004 | 06:49 PM
Myxtreme1's Avatar
Header leak...?
My MAC header install is just about complete. Only have a little while each day hasn't made it a cinch. The problem I have now run into is a massive leak on the middle section of the driver side. I have tightened down the two bolts with no improvment. ANy suggestions? Also how much did everyone else have to cut off the supplied cat flange? Thanks!
Old Jun 1, 2004 | 07:07 PM
med_reject's Avatar
what gaskets did u use?
Old Jun 1, 2004 | 07:17 PM
Myxtreme1's Avatar
The copper ones and the bolts that came with them. And the pass side isn't leaking at all from what I can tell.
Old Jun 1, 2004 | 08:40 PM
ABA383's Avatar
I just tried the copper ones on a friends 72 camaro...leaked like crazy...bought some good Fel Pros with the metal core and no more leaks...I have since heard of horror stories when using the copper....
--Alan
Old Jun 1, 2004 | 09:02 PM
whiteslpz's Avatar
I use percy's dead soft gaskets, and haven't had a leak its been 2 yrs
Old Jun 1, 2004 | 09:46 PM
stereomandan's Avatar
I had to take the copper gaskets off as well.
I bought the Mr Gasket Ultraseal's for the LT1 from Autozone for about $20. VERY similar design as the Felpro 1406 and has sealed up GREAT.
Dan
Old Jun 1, 2004 | 09:52 PM
Myxtreme1's Avatar
Well at least I know my next direction. Will I be able to get the gaskets out with the headers still bolted to the y pipe? Did anyone else have the same leak as well? I've heard it's a common area.
Old Jun 1, 2004 | 09:56 PM
You will have to loosen the two bolts on the y-pipe to collector connection. Easy to do though.
Dan
Old Jun 1, 2004 | 11:10 PM
SC97TA's Avatar
I use felpro gaskets with permatex ultra cooper on either side of the gasket. If your flange is warped bad you might need to get it machined.
Kris
Old Jun 1, 2004 | 11:45 PM
SiDeWaYZz28's Avatar
yeah copper gasket suck bawlls i just swaped over to felpro yester and no more leaks...man with those mr gasket copper i had leaks at every primary...go with a soft gasket u wont regret it
Old Jun 2, 2004 | 08:35 PM
med_reject's Avatar
I only remove the bolts that held the header against the head, leaving the one on each end.
Pulled the copper out (made my car sound like a tanker), and dropped the felpro in. It has hooks that catch onto the two outer bolts. Then i bolted everything back down.
Old Jun 2, 2004 | 09:05 PM
Myxtreme1's Avatar
man I sure wish someone would stock these things here in town. Looks like I will have to order them.
Old Jun 2, 2004 | 09:45 PM
)2overt SS's Avatar
I'm also using Mr Gasket... four thick soft metals layers
Old Jun 2, 2004 | 09:53 PM
Dan
Old Jun 3, 2004 | 09:28 AM
Myxtreme1's Avatar
So where else can I get the Mr GAsket?? Autozone here said they don't have it. And we have like 10 of em! Anyone have a part #? Thanks!
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
