Best aftermarket ignition box mounting locations
Old Jun 4, 2004 | 08:03 PM
RedHottG2's Avatar
Question Best aftermarket ignition box mounting locations
Where does everyone have there Ignition boxes mounted ? Most are on the fender in the engine bay I'm sure. Does anyone have an unusuall mounting spot for there's ? I know a guy that has his MSD mounted in his glove box to keep it out of the heat.
Old Jun 4, 2004 | 08:28 PM
19camaro71's Avatar
the box actually produces a considerable amount of heat. you could put it in your glove box, or on the driver side inner fender well right by the fuse box... There is a little indention that is flat. That is really the only place to put it in the engine compartment,
aside from moving the fuel lines back a bit, you shouldn't have much trouble.
Old Jun 4, 2004 | 08:31 PM
12SCNDZ's Avatar
My 7AL-2 box is mounted where my cassette holder used to be. MSD boxes shouldn't be in enclosed areas, such as glove box or console.
http://www.geocities.com/max_wylde/interior.jpg
Frank
n2ceptor's Avatar
Diddo... My accel fit nicely. Its alittle smaller than MSD..
Old Jun 4, 2004 | 08:40 PM
PG97SS's Avatar
Sorry to highjack the thread but at what point during modding should you add a ignition box?
Old Jun 4, 2004 | 08:43 PM
19camaro71's Avatar
if you plan on seeing serious power above 4000 rpm... you need a really decent ignition, but it doesn't hurt to have one anyway... better spark means better ignition. Power gains may be minimal on low modded cars, but the heavier the modding gets, the more you need one.
RedHottG2's Avatar
At high horsepower levels or when spraying NOS.
12SCNDZ's Avatar
My 7AL-2 and Blaster coil knocked 1.5 tenths off my ET when the engine was still completely stock....
Frank
Old Jun 4, 2004 | 08:45 PM
19camaro71's Avatar
no S***! would my car see 12's with the mods I have listed?
Old Jun 4, 2004 | 08:59 PM
12SCNDZ's Avatar
Two more pictures...
http://www.geocities.com/max_wylde/MSD1.jpg
http://www.geocities.com/max_wylde/MSD2.jpg
Frank
Old Jun 4, 2004 | 09:02 PM
12SCNDZ's Avatar
Mine went 12.82 before I ever pulled a valvecover for the first time...With exhaust maniflods...Through a Flowmaster @ full weight with a stock suspension.
Frank
Old Jun 4, 2004 | 09:08 PM
RedHottG2's Avatar
I'm remembering back to when I had my first F-body (93). This was before I knew the boxes needed to be mounted in the coolest possible place. I bought an LG Motorsport 3-point STB and starting thinking how cool it would look mounted sitting on top of it. Needless to say I toasted it..but I guess you live and learn.
Old Jun 4, 2004 | 09:16 PM
12SCNDZ's Avatar
Oops...I meant 1.5 tenths....LOL
Frank
Old Jun 4, 2004 | 10:33 PM
disco192's Avatar
mine is located deeper in the engine bay behind the drivers side light. It may not work with all cars because i have ram air.
Old Jun 5, 2004 | 01:06 AM
KWIK WS6's Avatar
From: Southern California, where do YOU live mutha****a?
I put mine behind driver side light[IMG][/IMG]
[IMG][/IMG]
