alternator only putting out 2v at 2Krpms, please help!!
Old Jun 5, 2004 | 02:06 AM
LT1RX7's Avatar
I'm trying to get my car running again and I've ran into somewhat of a problem. I wired the alternator as shown by painless wiring but I get no more than 2v. I hooked up one wire to a 12v source (S on pigtail). The other wire (L on pigtail) I installed a 15ohm resistor and wired to ignition 12v. Then the wire for the alternator charge on the outside of the alt's case. After I tried with the pigtail plugged in, I took it out and I got pretty much the same readings, 2v. Can someone tell me a way to test the alt w/o taking it out?
Old Jun 5, 2004 | 06:24 AM
slopokrodrigez's Avatar
Assuming you have it connected properly and the battery is GOOD, the way to test it is, put a voltmeter across the battery terminals. If the alternator is putting out correctly, the voltage across the battery will be close to 14 volts when the engine is running. The alternator must be hooked up to check it. With no wires connected or if it is connected wrong, it will have little or no output.
If you suspect the alternator is defective (which is sounds like it is) take it to an auto parts store to have it tested under load if possible. DO NOT buy an alternator or any other electrical part from the cheapy auto stores like Autozone or Advance. You will waste a lot of time and F!@# their lifetime warranty.
Old Jun 5, 2004 | 08:50 AM
Josh'95Z28conv's Avatar
Why not? They rebuild them and replace defective and worn parts. Should be as good as a new one...
Old Jun 5, 2004 | 10:13 AM
The only connection on the pigtail should be "L". It should go to your gauge/light or a 12v source with a 470 ohm resistor. Don't know if connecting the "S" hurt anything or not. Of course, you must have the battery cable connected to the large post.
DirtyDaveW
Dec 1, 2016 05:37 PM
Red97LT1
Mar 1, 2015 05:08 PM
Noer
Feb 28, 2015 11:29 AM
Gtpguy
Jan 26, 2015 04:50 PM
HectorM52
Jan 16, 2015 10:21 AM
