Should I upgrade injectors with my mods??
Old Jun 3, 2004 | 06:22 PM
detroit1994z28's Avatar
I have the following mods
94 camaro z28m6
58 holley throttle body had to bore out stock intake
lt4 hot cam
lt4 knock mod
k&N
aftermarket maf
trick flow
4:10 gears
march pulleys
1:6 rockers
shorty headers
Everything else is stock should I upgrade to bigger injectors. I have a 94 camaro z28. with stock injectors on the car right know. If so what size will I need - Mike
Old Jun 3, 2004 | 06:30 PM
n2ceptor's Avatar
stock (24lb) injector should be ok.. Only if you go to nitrious or super charger then go up.....
R@mpage
Apr 20, 2015 10:02 AM
QuickSilver02
Apr 7, 2015 11:12 AM
