where is the air pump located?
Old Jun 4, 2004 | 05:34 PM
gritter's Avatar
been blowing the fuse on it causing the ses light on my 94 t/a so im gonna disconnect it then toss a good fuse and the light should go out. Just wanna know where the damn pump is to disconnect it.
Old Jun 4, 2004 | 05:50 PM
RCF925's Avatar
Drivers side towards the front of the block
Old Jun 4, 2004 | 05:54 PM
1msfyter's Avatar
Mine is in my closet , where it belongs....
Old Jun 4, 2004 | 06:10 PM
gritter's Avatar
can it be unplugged without adjusting the height of the car?
Old Jun 4, 2004 | 06:13 PM
Spinner's Avatar
three bolts take it off with its bracket.
Here's a pic, courtesy shoebox's site
http://shbox.com/1/temp_sensor1.jpg
Old Jun 4, 2004 | 06:16 PM
gritter's Avatar
so it's under the car?
Old Jun 4, 2004 | 06:19 PM
Spinner's Avatar
It's on the front of the engine, I removed mine from up top, but it's just as easy to get under the car to do it
Old Jun 4, 2004 | 06:37 PM
From the top, you might be able to get to the electrical connector that is in the right hand side of that pic.
Some more views here.
Old Jun 4, 2004 | 08:48 PM
MarkyMark's Avatar
The tube that comes from your cai or airbox goes directly into the airpump. 3 bolts take it out and then 1 more bolt for the electrical connection up a little higher. You will also need to cap your manifolds and take out the long pipe that goes over and connects to the passenger side manifold. You will also need a vacuum cap for the cai or airbox.....I used a 3/4 inch cap.
Old Jun 4, 2004 | 09:13 PM
Josh'95Z28conv's Avatar
Not that kind of air pump. Camaro's dont have an air ride suspension
Old Jun 4, 2004 | 09:55 PM
96WhiteZ28's Avatar
what would happen if you happen if i disconnected all this without getting the PCM custom tuned first?
Old Jun 4, 2004 | 11:41 PM
Nestromo's Avatar
Check Engine Light.
I'm gonna have to get that programmed out.
Old Jun 4, 2004 | 11:48 PM
MarkyMark's Avatar
Yea I dont think anything bad will happen other than the check engine light. Yesterday I was bored and I took out my air pump leaving the egr on and the pipe that goes over to the pass. side blocking the manifolds and cai of course. I'm gonna take the egr and pipe out next week when I get some time, but so far I havent even thrown a code.
Old Jun 5, 2004 | 01:24 AM
screamin94Z's Avatar
only asking because its too late to go out and mess with the car, but do you have to route the belt different to bypass the air pump or does it require a smaller belt?
Old Jun 5, 2004 | 02:18 AM
gritter's Avatar
i was talking with a hoist or a jack....
