Compression testing
Old Jun 3, 2004 | 09:52 PM
jj93z28's Avatar
Compression testing
Is it absolutly necesary to remove all of the plugs while doing a compression test? I am just looking for one that may be the cause of my coolant in oil problem. I had thought it was my oil cooler but the oil level is rising again so it was not.
Old Jun 3, 2004 | 11:07 PM
To test all cylinders and compare accurate readings, all plugs should be removed. Can it be done without removing all plugs? Yes, but results may not be so accurate. A large problem would probably be easily evident, though.
KYWes
Jun 14, 2022 06:52 AM
Quickss96
Jan 29, 2016 05:56 PM
cmsmith
Sep 14, 2015 09:25 PM
karpetcm
Aug 14, 2015 03:02 PM
13qtr
Jul 19, 2015 05:30 PM
