Need Help Pleasee Read!!!!!!!!!!!
Old Jun 5, 2004 | 12:24 AM
LT1CST's Avatar
OK I need some major help. What the hell is going on with my car. My motor is new. 355 all that good stuff. I finished my LT install. No problem. I went to start my car and all of a sudden my REAR LEFT brake area was SMOKING. What the hell man. I though my car was gonna blow up and hit the fuel lines LOL, SO anyway Please tell me whats going on. I think theres somthing going on with my cables. There not the best in the world. |OH WELL> But I have never ever seen my REAR LEFT Brakc caliper start smoking From trying to start my car. Please HELP??????
CHris
Old Jun 5, 2004 | 12:32 AM
Bone Daddy's Avatar
electrical short of some type. check for any wires that may have melted together in the engine bay. Espescially since you did alot of work around the abs.
Old Jun 5, 2004 | 12:41 AM
LT1CST's Avatar
IS IT POSSIBLE THAT I MIGHT HAVE A GROUND WIRE TOUCHING A BRAKE LINE OR SOMETHING
CHRIS
Old Jun 5, 2004 | 12:44 AM
1 Nasty Bird's Avatar
a ground wire touching wouldnt be a problem really, its those darned positive cables that cause problems! your whole car is basically a giant ground cable. You have to make sure the positives are all sealed well.
Bone Daddy's Avatar
its possible, but there is an abs sensor back there, and you have something sendign power where it doesnt belong, thats for sure. Just go do a check.
Old Jun 5, 2004 | 12:48 AM
LT1CST's Avatar
ok ILL check it out in the mourning. BUt does this sound like it could be a major problem.? I hope not. Also. Theres a cable attaced to the Starter cable. IT seems to be loose. Im not sure if it needs to be mounted anywhere. But could that be a ground wire? IF so does it need to be mounted to the car. Thanks
Chris
ttt
Old Jun 5, 2004 | 01:14 AM
Bone Daddy's Avatar
check shoebox's site, he has a starter/charger wiring diagram.
check/compare
I just hope you have'nt fried more than your rear abs sensor.
DirtyDaveW
Dec 1, 2016 05:37 PM
ad356
Apr 22, 2015 08:35 PM
aj2494
Mar 12, 2015 10:17 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
