Coolant in oil but nowhere else
Old Jun 4, 2004 | 11:06 PM
jj93z28's Avatar
What would cause coolant in the oil but not the reverse? Also there does not seem to be a signifigant amount of coolant in the cylinders if any at all.
Old Jun 4, 2004 | 11:29 PM
If it were a head gasket problem, it would depend on what the leaking part of the gasket was adjacent to. It could leak into the cylinder(s) or just into the lifter valley or whatever. I am assuming you don't have a factory oil cooler.
Old Jun 6, 2004 | 02:50 PM
jj93z28's Avatar
I had one, I took it off in hopes that it was the problem. I have also allready replaced one of the head gaskets(should have done both at the same time). So I guess I am looking at the other headgasket or a crack in the heads or block.
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
FredM
Jun 5, 2015 05:45 AM
Nickster 7
May 1, 2015 09:04 PM
MattFick
Feb 15, 2015 10:16 PM
