egr removal
Is there anything you have to do so you don't throw codes? Some electrical stuff is messed up with my car, codes are for EGR and EVAP, but I think they are functional, just not getting power or something. If that turns out to be the problem.. I should just take it out instead of buying a new system from the dealer for it..
Just remember to block off the openings in the back of the intake and on the exhaust. I just had a friend weld up the ends of the tube after cutting off about an inch from each fitting. He also welded my cut-out in my off-road pipe, expanding the flare ends to fit over the cut-out. Bitched about the ceramic coating spitting like crazy as he welded it.
RX Speed Works
Jul 24, 2015 02:25 PM
Jul 17, 2015 02:47 PM
