Opti failure (again)
Old Jun 3, 2004 | 01:17 PM
TedH's Avatar
My last opti lasted a year. This one (brand new) only lasted two weeks.
Week one I drove 100 miles to the track, won the evnt, and drive home. I then parked the car.
Week two I drove 100 miles to the track and when I filled up with gas it never started again.
What should I be looking for to prevent this from happening? I do have another new opti which will be overnighted in tomorrow AM, along with a new harness cable and water pump gaskets and O ring. (it is a 1995 vented opti).
Can the PCM fry the opti?
Old Jun 3, 2004 | 01:44 PM
Kryckter's Avatar
Make sure you dont have any leaks near the opti. Oil leak on the opti could kill one pretty quick or an antifeeze leak could kill one. Check to make sure that the camshaft dowel pin isnt too long. I know if the dowel is too long it will put a load on the opti and make it fail premature. Also are you using AC Delco opti's? I hear that the other rebuilt ones dont last too long and arent too good.
Old Jun 3, 2004 | 01:49 PM
TedH's Avatar
AC Delco Opti.
I don't mind an annual replacement but every two weeks is excessive.
Can I just grind off the end of the dowel? Is a "little" short ok?
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
